jgrm1's Avatar
What Happens If I Remove This Bolt?
Look at the bolt with the circle around it. I think it goes to the timing chain guide rail. Can I remove it to replace it with something less corroded or will things fall apart internal to the cylinder?
Thanks,
Jeff
BMW: 2024 R1250RS, 2016 R1200RS (For Sale), 2000 R1100S, 1975 R90S
Ducati: 2008 S2R1000, 1998 900 SS/FE
Norton: 1974 Commando 850
Triumph: 2020 Speed Triple, 1976 T140V Bonneville, 1973 TR7RV Tiger, 1971 T120R Bonneville, 1970 TR6C Trophy
Old 07-24-2010, 10:35 PM
I don't know, but seems like a very poor tradeoff to risk a problem just so you can have a shiny new bolt in place of a (slightly from the picture) corroded one. Pick your battles.
- Mark
Old 07-24-2010, 11:23 PM
No try, do or not do
shreddr's Avatar
i think that bolt is #6 (farthest right) in this picture, i think i pulled that on my R12S without losing anything into the bottom end. how about a little metal polish and a dremel?
2017 R1200GSW Rallye Shreddr Signature Model
Old 07-25-2010, 04:31 AM
Schneller's Avatar
I would sand it down & touch up w/ some silver paint!
Schneller
Mike Morris
Schneller BMW Performance
26 Middle Rd Unit 1-2
Newbury, MA 01951
978.465.2002 www.machschnell.com
Old 07-25-2010, 05:49 AM
DO NOT REMOVE!!! Repeat, DO NOT REMOVE!!! The guide rails will drop down, and it will likely mean an embarrassing and expensive trip to the dealership if you can't move the guide rails back into place to insert the bolt.
To clean, put masking tape around the bolt and use a dremel and wire brush attachments to clean the bolt. Dremel makes three wire brush attachments, you'll want to use them all. If you don't have a dremel and the wire brush wheels, get one. It's ideal for cleaning bolts, and will cost you less than a dealership visit to have the guide rails put back into place.
Old 07-25-2010, 06:35 AM
Initials & assault rifle
cageyar's Avatar
Ditto big time.
Because I'm a moron, I removed that bolt in error in 2008 on my R12S. Sweated out a couple of hours using a wire coat hangar hook to lift the guide back up so I could get the bolt back in-DON'T DO IT!
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER
1982 CBX | OLD SCHOOL
1969 H1 | QUESTIONABLE SANITY
Old 07-25-2010, 06:40 AM
jgrm1's Avatar
- Mark
That is exactly why I asked the question. I knew someone here had the answer, so by asking the question before I started unscrewing things, I mitigated the risk.
Thanks for the responses. I have silver paint in hand and am on my way to pick up a Dremel.
-Jeff
Old 07-25-2010, 08:14 AM
shreddr's Avatar
of course i should qualify that i pulled mine with the heads off. looks like you have your answer.
Old 07-25-2010, 09:05 AM
jgrm: what part of Texas are you from? I'm in Sherman, near the Okie border and Lake Texoma. You'll be able to use the Dremel a lot on your bike. If you have a cheap tool place in your locale, get a non-Dremel brand there, which is basically a 1/8" shank die grinder. I've used my $19.95 tool for several years, it has 6 speed settings. Go to Home Depot or Lowe's and get all 3 wire brushes -- a regular wheel, a wide-based one, and a thin, round one to go inside an allen head bolt, about $4 each. You might also consider polished stainless steel bolts, about $50 for a complete set. I've replaced every visible bolt (except for the guide rail bolt and a couple of other ones) front to back on my '03 BCP with high-strength stainless. Am I anal? Yes, I even bought a set of R1200C chrome valve cover bolts & washers, and had my headers ceramic coated.
Old 07-25-2010, 03:23 PM
Honda GL1000 current ride
Martin Glasser's Avatar
Header pipes look good! Wave rotors look good!
Isn't anal short for anal retentive --- meaning uhh --
constipated thru mind over matter?
Wish high appearance mindedness had another name..
I might get that ceramic done on my pipes..
Old 07-25-2010, 04:03 PM
jgrm1's Avatar
It looks like I'm about 140-miles southeast of you in Tyler, TX, between Dallas and Shreveport. I work in Palestine, TX. I moved up here from Houston in February.
Thanks for the tips. My 'S was in the same condition as yours in when she was sold in 2007. I got her back last month. She's been neglected over the past three years and I'm working to get her back in shape.
-Jeff
Old 07-25-2010, 04:20 PM
bacn5's Avatar
A silver metallic "Sharpie chisel tip marking pen " makes touch up fast and easy.
2001 R1100SA Dakar Yellow & Black - Several Modifications
Old 07-26-2010, 07:17 PM
Or you can get a can of this and do it right. This is a perfect match.
Old 07-26-2010, 08:12 PM
jgrm1's Avatar
Thanks, Nail. Excellent suggestion. I have used Testers Model Paint in the past to touch up the flat black fairing fasteners and was going to use their silver on the plated bolts. I'll see if I can find this Wurth stuff. Where did you buy it?
-Jeff
Old 07-27-2010, 08:16 AM
Bubba THAT IS A PERFECT MATCH FOR YOUR HAIR!!
Old 07-27-2010, 08:54 AM
Cyclone Jack
hawkeyejohn14's Avatar
Bubba you need to cut those finger nails before you hurt someone.
jc
2004 R1100SA Pacific Blue
Old 07-27-2010, 09:38 AM
-Jeff
I got mine from Touring Sport in Greenville, SC; but, I think you can google it and find a dealer near you.
How do you expect me to pick my nose?
Old 07-27-2010, 02:15 PM
Cyclone Jack
oh! lol
jc
Old 07-27-2010, 03:27 PM
