-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   Installing speed bleeders (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/572697-installing-speed-bleeders.html)
RIQUE 10-30-2010 06:55 PM
Hey folks, I purchased a set of speed bleeders for my front caliper. I wanted to know how should I go about installing them. Should I just unscrew the old nipple and replace or must I follow certain procedure. No instructions in the new speed bleeder box.
bikerfish1100 10-30-2010 07:34 PM
pretty much straight ahead- remove the old ones, install the new ones. some fluid will dribble out, so have a rag nearby. on the right side, if not already done, remove the entire housing that the grub screw sits in. basically, remove everything that keeps the right side caliper from looking like the left.
when you go to bleed fluid, just back the SB out a bit to allow fluid movement, then proceed as you normally would for bleeding.
Guest24 10-30-2010 07:39 PM
Keep in mind that brake fluid is hard on any finish that it remains on.
Guest24 11-10-2010 06:41 AM
How often to you replace the coating on the threads? Rique, you can see the ball and spring poppet valve. It allows the fluid/air to go one way. You can do the same with a vacuum bleeder.
http://www.ascycles.com/images/produ...brakebleed.jpg
