diz plaz is cwazy
Installing speed bleeders
Hey folks, I purchased a set of speed bleeders for my front caliper. I wanted to know how should I go about installing them. Should I just unscrew the old nipple and replace or must I follow certain procedure. No instructions in the new speed bleeder box.
Life rewards action, He who is not afraid is safe! A Zest for living requires a willingness to die! -------------------------------------------------------- BWM R1100S 2004 (fat girl) BMW S1000RR 2011(skinny BMW R1200S 2007 (stingger) Honda CX500TC 1982 (turbo) |
pretty much straight ahead- remove the old ones, install the new ones. some fluid will dribble out, so have a rag nearby. on the right side, if not already done, remove the entire housing that the grub screw sits in. basically, remove everything that keeps the right side caliper from looking like the left.
when you go to bleed fluid, just back the SB out a bit to allow fluid movement, then proceed as you normally would for bleeding.
"Wow I'm an idiot, thanks bikerfish!" Harleys are like opinions, every a-hole's got one! 2001 R11S "lite", with a few mods. 2009 F800GS. has a better saddle. and other stuff. (sold) 2016 R12GSW 3Black. wow. |
Keep in mind that brake fluid is hard on any finish that it remains on.
How often to you replace the coating on the threads? Rique, you can see the ball and spring poppet valve. It allows the fluid/air to go one way. You can do the same with a vacuum bleeder.
