Lane
2005 Boxercup, 2013 R1200GS Rallye, 2011 Triumph 675 Daytona, Honda MB5, 2011 KTM300xc, 1975 Bultaco, 1992 Beta, 1972 Aermacchi |
Talk Less, Say More
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
I thought that during some prior discussions of this issue many years ago, we as a group, amongst ourselves and no one else, also and additionally, after drinking a lot of our internal Kool-Aid, determined that through extensive metallurgical testing and eyeballing, that there were some softer spline shafts being passed on through production. These were stockpiled and dispersed randomly among different BMW models. With the exception of the f650 series. I believe a thorough search will uncover this hideous secret. Look/search for "An uncomfortable yet inconvenient truth, BMW motorcycle manufacturing quality control and manufacturing tolorances" by Alfred GorE Neuman.
cRaIg CaRr 2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer. |
Everything said has some merit. Its 39 degrees and 10 percent chance of rain, I'm going riding.
sorry I can't tell U exactly what my mechanic said. Something about the assembly. Sorry dude. You'll never know. Cuz I forgot.
Joe, how well balanced do you think the clutch disc is? When I get back to Das Bikehaus, I'm going put the old clutch disc that i have and see how it does on the wheel balancer.
BMW (or their supplier), mark the spring,pressure plate, and clutch cover with a paint mark. Usually white. These marks are supposed to be 120 degrees from each other. tjs
The very 1st 2002 R1150RT's were the most frequent model for clutch failure in the shop I worked at. Usually within 20K. tjs
'07 R1200S
I could I went for a quick 80 mile romp Sunday afternoon and had two different incidents; the first happened running about 60 in 4th or 5th, when I changed directions in a turn the bike felt like it missed. I was low on fuel, but the light hadn't come on yet, so I hit the next station and filled up. About 30 miles later, going a steady 65 on a straight stretch of road in 5th, there was a 1/4 second where the the bike sounded/felt like it hit a neutral. I rode very gingerly home and hope to pull the starter this weekend.
I hope I'm not willing this thing to fail. |
In any event, it happened to my bike perhaps five times in 55K miles with no rhyme or reason and seemed to diminish with miles - did not happen in last 20K or so. The symptoms of input shaft spline failure are typically not subtle nor progressive - the bike suddenly loses thrust and won't go from this point forward, accompanied by mechanical noises. Your two incidents may be indicative of a problem (or problems), but I doubt it is THIS problem. - Mark |
I just had this happen to me on my way home, and not for the first time. Cruising in 6th gear around 70mph and for about 1/4 second, it felt like the clutch let go and then caught again, of course causing a bit of a lurch forward. The rest of my ride home was me convincing myself I need to hurry up and trade this bike in before the input shaft finally fails and I'm due a huge repair/parts bill. However, it sounds like it's not related at all...bike just kinda fell out of gear, I guess. Very odd. I've had it happen thrice in the past 4-5 months, each one has gotten progressively more severe (longer duration of no power to the wheel)
2002 R1100S Boxer Cup Prep Remus full exhaust, Lenny's intake, boosterplug |
Your problem reads like ignition cut out.
Kent Christensen Albuquerque '12 R1200RT, '02 R1100S '01 Boxster |
Could be, tough to really say. I mean, the engine doesn't sputter or anything, it just speeds up as the connection to the rear wheel is lost momentarily.
unsafe at any speed
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
So, after pulling the starter how do you tell if the splines are OK? I pulled my starter today to have a look at the splines and clean the starter. I can only see about 1/8 inch of the splines and the clutch hub. Nothing looks chewed up, rusty, oily or heat scorched. My bike has 35k on it.
Last weekend I helped my buddy pull the transmission on his R1150R and there is a good inch or so that I know I can't see. At 40k his splines look like new, he blew the rear main seal overfilling the crankcase and ruined the clutch. His slave cylinder leaked too, so we need to run it to the dealer to replace the seals. My slave cylinder failed, bad bearing - no leak, at 20k I'm replacing the current one at 40k.
Doug Minneapolis, MN '01 R1100S ABS, Öhlins, Ztechnik exhaust, Corbin "Ol' Yeller" '03 Yamaha TW200 "Skippy" |
Ride Free or Die
The surest sign that you are about to have a spline failure the a slight tug at the pocket your wallet is in.
I wanna Live 'til I die!
Ah, yet another quality post....
Light travels faster than sound. This is why some people appear bright until you hear them speak... https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729 2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901 |
Pull in the clutch lever and tie it off. Then, looking through the starter hole, find the edge of the clutch disk. Using a small tool of some sort rotate the clutch disk back and forth as you look into the slot at the splines. The splines and disk should move in unison. If the disk can move on the splines you have trouble. If you have a problem you can measure the play at the edge of the disk. Once it gets to a quarter inch I'd be seriously shopping for a used known-good transmission.
Jim Moore Jax, FL '01 R1100S '07 CBR600RR |
Ride Free or Die
The difference being that I am informing people of upcoming, interesting activities... and you are just posting your usual, idiotic stuff...
Carry on.
