No try, do or not do
Brembo Blues!
I didn't like them as yellow, but blue sure does the trick!
2017 R1200GSW Rallye Shreddr Signature Model |
Hey Shreddr...........is that the paint and roller you used in the background?
Cheers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat |
WoW! This is your 427th thread, Jeff.
I wanna Live 'til I die!
Yeah, but 425 of them were about the Wösner Pistons and how good a job he did...
Light travels faster than sound. This is why some people appear bright until you hear them speak... https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729 2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901 |
Dont taunt happy fun ball
I'd think on a black bike that gloss black would look awesome. Regardless, certainly better than the washed out, dull black that the OEM paint turns into in about 2 minutes.
Although pixels are cheap, your contributions are taxing. Please stop. |
Ghost Spoiler
shreddr any chance of a full bike pic with these suckers on?
I have a hard time working out what you think is "ghey" and what you think is rockin - but anyhoo, a full bike shot would be good
i will, i need to get the rear one on.
I see you
Shred, did you strip them first? Any concerns with heat retention?
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
it's high temp powder coat, i doubt it is going to cause me any adverse effects.
Ghost Spoiler
Private Citizen
Shreddr,
What bike are the calipers off of? The stock ones have BMW cast into them, where those appear to have Brembo painted on them. I bet they will work really nice once you hook hoses to them.
Rob Swartzwelder llllllllllllllll 97 M900, 07 R1200s(sold), 07 G650X Challenge, 99 BMW R1100S (Brad Z on CF Dampeners)"it's the perfect blend of sophistication and bling." (Roger A on moderation) "Note to thin-skins and panty-bunchers - please note smiley." Last edited by AZ-Twin; 02-17-2011 at 09:18 PM.. |
Sure it's technical. It aids heat retention. That's good, right?
![]() Seriously, it's a street bike, and thus by definition, mostly for looks, so it's not as if it hurts anything particularly. If blue 'bos are to your taste, then it seems good. We haven't been too technical for a long time, so what's the harm.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
Registered ab-user
![]() Back to topic: I have the same concern as Roger: about heat retention. So I 'd have suggested against powder coating if I was asked. Brembo has a special paint for calipers. Besides that: it looks great. |
Initials & assault rifle
Brembo, as a vendor, will coat calipers based on what ever spec the manufacturer requests or is willing to pay for - one of the "cost" measures on the otherwise stellar Mitsubishi EVO is the Brembo calipers are painted.
Brembo offered red powder coat but it was more expensive so the calipers are simply painted red and then clear coated. Be careful when you change the fluid - you know why......... Needless to say, Brembo won't cover those calipers for surface finish degradation.
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER 1982 CBX | OLD SCHOOL 1969 H1 | QUESTIONABLE SANITY |
I am sure they will work much better once I hook them up, but i had to test fit them to see how they looked! I have the rear caliper as well. I like it!
Registered ab-user
Never saw a caliper with powder coating on a race bike that was built by pro teams. So I never won't do that on a race bike or a street bike whose brakes are used intensively. Certainly there isn't a problem if granddaddy and grandma go bike-traveling on an easy tour. |
it seems obvious that any coating over a part that heats up will tend to hold in the heat, but i think the extent may be exaggerated. i have searched for some "real" research regarding the heat retention properties of powder coats, and I found nothing. it seems to be anectdotal or minimal at most. I found this blurb on a powder coaters website:
"Harley has been coating the cylinders with black wrinkle powder for years. Chrysler was doing the same with powder on the truck blocks also. We have done real world testing here. We coated Chevy blocks and also cast iron heads and accessories such as carburetors, water pumps and alternators. Infrared temps were taken before an after powder coating. The heat retention in the powder coated components was minimal less than 10 degrees difference between the coated and un coated parts. Once the powder coating is heat cured it will radiate or transmit heat at the same rate as other liquid paint coatings applied at the same mil thickness." the powder coater I chose Andrews Powder Coating. Custom and Semi-Production Powder Coating. knows motorcycle parts, and the function of brake calipers, and they adjust their powder mix accordingly. as far as race teams go, because they are operating at the 99.99% level any performance gain or loss is real, so perhaps that is why they don't powder coat those parts, that plus the fact that you don't cover machined billet! ![]() like i said it is pure aesthetics. the OEM brembos are actually a pretty respectable set of calipers, BMW just uglied them down to the point of invisibility. my little project just displays them better, and rids them of the cheap looking BMW logo. for such a brand centric company as BMW I am surprised they didn't let Brembo leave their logo on in the first place.
2017 R1200GSW Rallye Shreddr Signature Model Last edited by shreddr; 02-18-2011 at 05:48 AM.. |
you missed your calling, you should have been an accountant.
![]() QUICK, count your balls, what number do you get? NOW, do it again, do you get the same number?
2017 R1200GSW Rallye Shreddr Signature Model Last edited by shreddr; 02-18-2011 at 05:46 AM.. |
