sɹǝʇndɯoɔ sǝʇɐɥ
BikerMiker's Avatar
Need help: Front End Tweaked?
I just had my 6000 mile service done today at Eurocycles of Tampa. They are the local BMW dealership and I had them do the work so there is no questions if a warranty issue comes up + I don't have the time.
I told them that I had gone down, described in detail the scenario and that now the front end "feels" tweaked. I can tell that the left handlebar is lower than the right and it is visibly ( to me ) off on the front.
They took a look at it, told me they realigned the front a little but it was absolutely fine and nothing is wrong with it. It tracks straight handles well and was verified by the senior mechanic and the service manager on separate rides. I sat on it and could still tell something was still amiss so I approached the service manager again and tried re-explained my concerns. We agreed I would ride it for a little and if I still felt it was out to bring it back.
What concerns me is that
1. They obviously didn't do any measurements
2. They can't tell by riding it that something is off. I brought it back to work and had other people sit on it and asked a non-leading question... "how does the handlebar distance feel?" All of them agreed that either the right one is high or the left is low.
3. I explained where I thought the problem might be and they either don't want to do the job
4. Or can't do a thorough job
5. Or they think that it really is ok.
Any of those throw up red flags.
All I really needed from them is a thorough check on the issue and an estimate and I feel that they, for whatever reason, aren't up to the task. Miserably.
I'm considering taking it 60 miles south to another (more reputable place) in Sarasota but I'm wondering if it will be even worth it as I expect the same attitude/ineptness from any dealer.
I'm looking for some advice from those in the know, on a reasonable path to take or something less obvious that I might be missing but I am 95% sure I know where and what the problem is.
I also went into detail about the frame that attaches to the triple clamp. I told them to check it because I believe it is bent. I got the response "...oh, that's a lot of work to get to that... ...this is the first one of these bikes we have ever dealt with..." Really makes me feel confident
I'm at the point where I'm thinking just going to do this myself because, again, another situation reinforcing all of my other bad experiences with dealers/dealer mechanics in general.
This also confirms that I'm crazy. A sane person does not keep doing the same thing over and over and expecting a different result.
I'm wondering if I should even bother with these people again or gather my resources, confirm the issue and tackle the job myself. Which leads me to my next question...
Those of you that have dug this deeply or have done the job: What are difficult areas and what should I look out for? Unseen consequences? Cans of worms? If I do this it will be my first major surgery on this bike but am a decent amateur mechanic.
Is there something else I should check too before I go headfirst into an expensive repair that may be completely unwarranted?
Bike tracks perfectly as I can tell ( tested 115+ ). Would that be the case if, what I am theorizing the problem to be, true?
I am going to fix this one way or another and any useful input from you guys will hopefully expedite the process.
Thanks in advance and enjoy your weekend...
Mike
'07 R1200S
Old 05-27-2011, 12:38 PM
roger albert's Avatar
If you automatically expect that, then you should do it yourself. It's darn hard without the right tools, and a lot of practice, to determine straightness. And not as many factory jigs for that anymore. That's why few shops do it. Sounds like your shop is not up to the task, and that you don't trust shops anyway, so this one may be on you.
In most cases, it's a matter of tweaked bars if it all tracks straight. I'd work hard to rule them out before digging deeper, which as they said, is not straightforward.
Good luck
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 05-27-2011, 12:53 PM
Initials & assault rifle
cageyar's Avatar
Any of those throw up red flags. Yes
I'm wondering if I should even bother with these people again...No
Those of you that have dug this deeply or have done the job: What are difficult areas and what should I look out for? It's not that diffcult - the lower ball joint nut is tight, that's about it.
Unseen consequences? Other than fixing it, no
Is there something else I should check too before I go headfirst.....Measure the alignment and wheel track like you've done in your illustrations. You can also use plumb bobs. Remove the bodywork and inspect the front frame closely for paint cracking-chipping. That's a sign it's bent
You seem like you know what to do.
Measurments vs. the dealer method is the key to finding the issue.
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER
1982 CBX | OLD SCHOOL
1969 H1 | QUESTIONABLE SANITY
Old 05-27-2011, 12:55 PM
I believe GMD Track Time in Atlanta has the computer alignment settings for the R12S from doing work for Nate. They might can help you.
Old 05-27-2011, 01:00 PM
Agreed. That would be the fast and precise way, and is at least not WAY to far away.
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 05-27-2011, 01:12 PM
ATA ATA is offline
... "barking at the wrong tree" scenario I guess!
1- simple seat padding/your ride position
2- rear wheel is going out of line (x2 for feel of it) and it shows when you load bike(x4)
Old 05-27-2011, 01:37 PM
sɹǝʇndɯoɔ sǝʇɐɥ
BikerMiker's Avatar
Does anyone have an experience with the one in Ft. Lauderdale area? That's half the distance.
I was going to dig into the triple clamp/handlebars this weekend. I replaced the left one which was bent but a lot less than I was hoping for.
Let me re-phrase that dealer portion to just include the ones in my general area. I know nothing about the others except Pittsburgh (bad experience) Knoxville ( good experience but that was just for a part ) and Atlanta which according to my friend was great.
Most times I go to a dealer for an issue it turns into a bad Threes Company episode. Trying to sell me unneeded equipment or service, unresponsive or rude. Poor technicians or technicians that just got out of tech school it goes on and on. All I want is someone to take my problem seriously and not rush me out the door to get the next shmoe in there. How about not having to make several inconvenient trips to solve a simple issue. I'm not just talking about MC dealers. Most of my problems with them are covered in the VW Mini Van saga... I just want to stroll in and have all my problems magically washed away by throwing money at them. They would say "yes sir no problem we can do that! All your wishes will come true. Do you need a beer?"
Is that too much to ask?
I really am not trying to bash dealers... I'm sure they have to deal with morons all day.
I guess I expect too much... Florida is the land of incompetence.
Mike
'07 R1200S
Old 05-27-2011, 01:54 PM
cageyar's Avatar
Most times I go to a dealer for an issue it turns into a bad Threes Company episode. Trying to sell me unneeded equipment or service, unresponsive or rude. Poor technicians or technicians that just got out of tech school it goes on and on..
I'm shocked, shocked to find gambling at Rick's......
Old 05-27-2011, 01:58 PM
sɹǝʇndɯoɔ sǝʇɐɥ
BikerMiker's Avatar
Whoa.... you have to explain yourself. I'm a little dense and this will take me hours to decipher.
Mike
'07 R1200S
cageyar's Avatar
You're too young.
Rent Casablanca......
Casablanca (1942) - IMDb
Old 05-27-2011, 02:01 PM
ATA ATA is offline
one of my older bikes had had "geometry issues"
started with clip-ons (bars); seat (it was slipping of one of the pads- made it worse!; well after all the long- it was missing washer against swing arm... (1mm thick, but had even affected tire wear)
"Barking..."?- see as what else could be to blame- not front geometry first
anw wish you persevere and get to the bottom of it, without entrusting dealers too much
Old 05-27-2011, 02:11 PM
I hunt deer with my BMWs
Psychopath's Avatar
Sounds like your bike is done for. I'll take it off of your hands for $1000.
2004 R1100SA (Street/Deer Spear)
2003 Suzuki SV650 (Track/Race CCS Expert#57)
2007 R1200S (SV650 replacement)
Old 05-27-2011, 03:01 PM
sɹǝʇndɯoɔ sǝʇɐɥ
BikerMiker's Avatar
That didn't take too long
Mike
'07 R1200S
Old 05-27-2011, 03:16 PM
Gasteropod Rider
Meeni's Avatar
In Knoxville, there is a place called shradder collision repairs and painting. Marc Shradder is the owner and mecanic in the place. He. shiuld be able to handle a problem like this one. I have been very pleased with service and the family like welcome at the place.
Old 05-27-2011, 08:52 PM
sɹǝʇndɯoɔ sǝʇɐɥ
BikerMiker's Avatar
That's a little far... but.... I'm willing to take the suspect piece off and send that to him or anyone else... the rub is that it may only be off by a fraction of a degree. Not enough to affect handling too much at all but enough to annoy the **** out of me. Cage had stated to look for crinkled paint but this is such a minute deflection I am not expecting to see anything obvious. I'm guessing it's off by .7 - .85 of a degree if it is the front uh... "frame thing" (what is that called?). It is definitely in the front. Can't be the triple tree because it's aluminum and there are no cracks but I'm going to scour all those pieces anyway.
Do you have his contact info?
I think this is something that some others would let slide. It really is close. The bike is completely rideable but it's driving me nutzzzzzzzzzz.
Will call GMD too and see if they will check a part. From what I read it seems like it would be possible.
Mike
'07 R1200S
Old 05-27-2011, 09:36 PM
Mike, I'm going to ask a simple question. Have you thought about loosening the pinch bolts on the top clamp and seeing if the drop twisted the front sliders a tad? I think the tubes would show some scarring if they had twisted during the drop. See if tubes show evidence of twisting in the area of the 3. I think the top ball-joint would have protected you somewhat from springing the frame at the neck. The bars pushing against the wheel would provide a good twisting moment. It wouldn't take much movement there to affect an appreciable bar end displacement.
Old 05-28-2011, 04:40 AM
Dont taunt happy fun ball
AndrewA's Avatar
Send a message via AIM to AndrewA
Undoubtedly, one of your tubes got readjusted when you fell off. This is very easy to do as there is minimal torque put on the pinch bolts.
Here is how you readjust.
Put the bike on a stand or lift so it is vertical.
Slightly loosen the top pitch bolt
Slightly loosen the lower pinch bolts
Stand in front of the bike, with the wheel between your legs, and hold it as straight as you can.
Rotate the bar that you think is low out a little – keep moving the bars back and forth to their stops until they are equidistant from the tank, ie both bars should be the same distance from the tank plastics at full lock, which is something like an inch or so.
Tighten.
You may want to do this a couple of times until you are satisfied that everything is straight. There are threads around that describe using string to make certain that the wheels are aligned, but I’ve always been able to get alignment pretty spot-on just by eye.
A lift is preferable to a stand because it will take some weight off of the front wheel. If you don’t have one it’s no big deal; just don’t loosen the pinch bolts too much, and make sure that you push the tubes down if they slide up.
If you don’t have a torque wrench, now is a good time to get one.
Old 05-28-2011, 06:26 AM
unsafe at any speed
wswartzwel's Avatar
May just be a bent handlebar. They bend easily.
Or you may need to pack one saddlebag with lead as a past member here used to promote.
Hi AndrewA Hope all is well in your world.
Bill Swartzwelder
Old 05-28-2011, 07:01 AM
ranadrew's Avatar
"We agreed I would ride it for a little and if I still felt it was out to bring it back."
The service manager is just covertly providing you a chance to recalibrate to the change. He is banking that it is subtle enough to not be readily quantifiable. If it feels wrong, it is. Went through that on a rebuilt salvage bike. Finally determined fork stanchions were just slightly bent, also replaced the lower fork brace just cause there was something odd there catching my eye but I could not quite see... if that makes any sense. Basically did the front end in my garage without the aid of any special tools, lifts, etc. It lines up perfect now and rides much different. Apparently, it does not take much deviation on a front end alignment to tell your body/brain that something is not square. There was just something weird in the handling and I did not have enough hours on the bike to put my finger on it... but I knew that I felt it. If you're feelin' it, do not let anyone talk you out of it.
Old 05-28-2011, 08:42 AM
my attack plan would be:
buy new bars.
before you install them, loosen every bolt that pinches, from the front axle to the rotor mounting bolts, to triple clamp and inbetween.
loosen everybody up.
put a couple rubber bands around the front brake to help center the pads.
tighten the axle.
snug up the calipers
move upward, including andrew's thing outlined above, until you finish by tightening down the new bars (left and right).
then go see.
really, it's possibly just twisted up and ticked off, but unlike most of us on this board, it can be un-twisted and returned to normal.
use a good torque wrench and follow the manual for correct torque clicks.
(talking about the bike here: using torque wrenches on board members doesn't seem to make them any smarter/better/nicer, though it can be self-satisfying).
Old 05-28-2011, 09:14 AM
