lht lht is offline
1200R Tap
I'm working on a friends R1200R replacing the rear tranny output shaft
seal. The pivot adjuster for the swing arm is is 24 X 1.25 mm thread.
I'd like to clean the threads up on the rear sub frame before putting it together.
Anyone have any idea on finding a tap ?
Thanks Lance
LT
Old 06-07-2011, 05:00 PM
ricky racer's Avatar
Go to a machine shop where you see some bikes parked out front and bring the sub frame with you. Go in the employee entrance and ask for the supervisor. Ask if you, or someone there, can run a tap through the hole to clean up the threads. Chances are you'll get it done for nothing. It usually works at our shop.
Old 06-07-2011, 06:20 PM
tm1100s's Avatar
If that doesn't work there's a couple 24mm taps on ebay for about $40.
tm
(R12, R11, R1) + 00 then S, S, /7
Old 06-07-2011, 06:49 PM
lht lht is offline
tap
I removed the swing arm without taking the sub-frame off. No need to take it off with the swing arm. Typical BMW they used an odd ball thread pitch. Their engineers suck. A 20.00 dollar tap becomes a 50.00 dollar tap.
LT
Old 06-08-2011, 05:27 AM
