BST Wheels
For you guys with BST wheels,are they wearing well??
Old 09-19-2010, 09:48 AM
Droptarotter's Avatar
Yes.........I just did a 2k trip through Washington and Oregon with them.....and have another 1k on them running around here........still no problems so far.
Cheers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat
Old 09-19-2010, 11:52 AM
Initials & assault rifle
cageyar's Avatar
I have 10,000+ miles on mine and I've performed three tire changes.
The wheels are perfect-get them before they're gone.
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER
1982 CBX | OLD SCHOOL
1969 H1 | QUESTIONABLE SANITY
Old 09-19-2010, 01:48 PM
No try, do or not do
shreddr's Avatar
10,000+ trouble free, gorgeous miles here!
2017 R1200GSW Rallye Shreddr Signature Model
Old 09-19-2010, 02:15 PM
Gone Bush
twodear's Avatar
Posts on the Forged wheels thread sort-of state that the cost of BST wheels were around $3000. BST doesn't sell direct, OPP website quotes $4006 per set.
Shreddr and Cageyar, who was your vendor and were the prices paid by a result of a group buy?
If enough is enough and more is better then too much should be just about right.
Member of AAAA (Association Against Acronym Abuse)
'22 H-D 'F' outfit, '46 Indian Chief outfit, a couple of early Honda Benlys, "BUBba" - R1150GS Adventure
Old 09-19-2010, 06:40 PM
shreddr's Avatar
I bought mine off eBay from the South African distributor.
Old 09-19-2010, 06:54 PM
LeftCoast Peter's Avatar
Bryan, where is your faithful riding companion?
2008 HP2S Sport Touring
2009 525 Beta RR
North Vancouver
Old 09-19-2010, 08:52 PM
If you look just above the shifter...........you will see him.
My wheels were bought form a guy in SA also........around $3K shipped.
Cheers
Old 09-19-2010, 10:28 PM
cageyar's Avatar
I bought mine from the U.S. distributor, Motowheels, in Sacramento, CA.
I paid the price listed. They assisted me in getting BST to make a modifed left disc carrier. I discovered the issue when I used Braking wave rotors which are .5mm thicker than the stock rotor. The BST front wheel has no offset and the thicker disc hit the caliper. BST now has a part # for a modified carrier if you're not using stock discs.
Click on the link for each wheel, F & R, scroll down to the bottom and you'll see a familiar bike.
Motowheels - Quality Motorcyle Parts and Products
Old 09-20-2010, 01:19 AM
Thanks for the info gents,got more than a bargained on which was very usefull.
Old 09-20-2010, 02:08 PM
Well they turned up today,very nice.
Old 09-29-2010, 04:56 AM
cageyar's Avatar
It is very tight getting the rear tire on-you need a NoMar tire changer or someone who is familiar with putting tires on a wheel with virtually no well. Don't let the average dealer hack attempt to put a tire on that wheel.
Old 09-29-2010, 05:23 AM
Thanks for that,but with two other bikes with Dymags i'm finicky who puts tyres on my wheels,I have a solus motorcycle tyre outlet less than half a mile away from were i live,and choose a 50 mile round journey to go else were instead!!!,but thanks again anyway.
Seems a shame to use them,would make a nice feature hanging on the living room wall.
Old 09-29-2010, 05:57 AM
Yep...............Cage is right with that quote............and check the Torx socket you have for the rear wheel............it might not fit in the holes on the BST wheels.
I had to grind a little off of my socket........and then I did get a nice Snap-on one that fit.
Post some pictures once they are mounted up.
Cheers
Old 09-29-2010, 06:02 AM
NakedRider's Avatar
+3. I've done a few of these with my NoMar. Make sure the tire is nice and warm. It's MUCH easier that way.
'09 BMW R1200R
Old 09-29-2010, 11:34 AM
Well finally got round to putting tyres on,whoever invented tyre warmers e'h!!.
Next question,what is the tolerence on the front wheel rotor carrier as you have to allow for the ABS ring as opposed to a bike that is non ABS,have BST assumed all bikes are ABS and non ABS need a spacer.
Old 01-12-2011, 07:23 AM
cageyar's Avatar
Does your bike have ABS or not?
The issue is that bike with ABS need a modified left front wheel disc carrier to compensate for the 1.1 mm thick (my measurement) ABS tone ring.
The modified carrier has a separate part number but it is visually different as well.
The 5 "ears" of the modified carrier are machined .5 mm on their outer surface and the inner surface where it mounts to the wheel is also machined .5 mm. This compensates for the tone ring thickness.
This is only necessary if you are using after-market discs which, in my case (Braking) were .5 mm thicker and the left disc just kissed the left caliper.
If you are using stock 4.5 mm discs, it should not be necessary to have the modified carrier - shreddr has stock discs and stock carrier and has no clearance issue.
If you don't have ABS, is the disc hitting the caliper on the inside surface? Then, IMO, you'd need about a 1 mm space to move the left disc out.
Old 01-12-2011, 07:46 AM
Yes I do have ABS,what I was interested in,what had BST assumed, that most were with ABS,if they have gone with majority and assumed that non ABS users would space theirs.
I'd noted that your aftermarket discs needed a different left side carrier.
Old 01-12-2011, 07:55 AM
Chris;
Check this link.......I think it gives the info you need.
I might be able to find you the part numbers of the adaptors if you need them.
Christmas Arrived Early
Cheers
Old 01-12-2011, 09:06 AM
I think for anyone ordering a set of these wheels, it would be advisable to include a pair of the optional disc carriers.
They do not add that much to the cost and it does give you an option if you go to different rotors later.
Cheers
Old 01-12-2011, 09:33 AM
