-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   How to access the fuse holders without removing the fairing (1100) (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/666666-how-access-fuse-holders-without-removing-fairing-1100-a.html)
Noblehops 03-19-2012 08:09 PM
OK so with the recent discussion about accessing the fuse holders without removing the fairing, I thought it might be helpful to photograph what's happening under the bike, and how they mount, so people can visualize what they are doing when they reach in there. The key thing you need to remember is that when you reach in and grab these, they both need to rotate roughly 45 degrees COUNTERCLOCKWISE, and then they will release and can be pulled out of the mounting bracket.
Put differently you must push DOWN on the rear of the one on the left side, and pull UP on the rear of the one on the right.
Left side, secured. Note the black bit poking through the bracket is rotated to secure it:
http://noblehops.smugmug.com/Motorcy.../IMG2316-L.jpg
Left side, rotated slightly to the 'release' position - note that the black bit and the hole in the bracket are now aligned:
http://noblehops.smugmug.com/Motorcy.../IMG2317-L.jpg
Right side, in the secured position:
http://noblehops.smugmug.com/Motorcy.../IMG2318-L.jpg
Hope this helps someone, someday. Maybe me :D
N.
wswartzwel 03-20-2012 05:39 AM
Better show them how to unsnap the cover while your at it. :)
RBMann 03-20-2012 09:41 AM
Mine have always been zip tied so I learned how to pop the cover off while they are in place. I don't remember if the zip ties were OEM.
Noblehops 03-20-2012 10:50 AM
I should have mentioned - my left one was ziptied, but I couldn't see a good reason why, and thinking about the guys that were having trouble with this, and the potential to need to access it by the side of the road, I removed it. It did NOT look OEM, was kind-of askance.
N.
Corky 03-20-2012 11:19 AM
Pretty easy to do once you've done it a few times.
It's all right in front of your eyes, it's just whether u can get your fingers in there without drawing blood. The fuse placement inside the fusebox is in the manual.
If U do it the hard way by taking the fairing off U learn quick. That is a pain in the hind end.
