Misfit
Noblehops's Avatar
How to access the fuse holders without removing the fairing (1100)
OK so with the recent discussion about accessing the fuse holders without removing the fairing, I thought it might be helpful to photograph what's happening under the bike, and how they mount, so people can visualize what they are doing when they reach in there. The key thing you need to remember is that when you reach in and grab these, they both need to rotate roughly 45 degrees COUNTERCLOCKWISE, and then they will release and can be pulled out of the mounting bracket.
Put differently you must push DOWN on the rear of the one on the left side, and pull UP on the rear of the one on the right.
Left side, secured. Note the black bit poking through the bracket is rotated to secure it:
Left side, rotated slightly to the 'release' position - note that the black bit and the hole in the bracket are now aligned:
Right side, in the secured position:
Hope this helps someone, someday. Maybe me
N.
Nils Menten - Tucson, Arizona, USA* 2001 R1100S "Light", gone but not forgotten. http://tinyurl.com/zv3tpc5
I Do Vapor Blasting! Visit restocycle.com for information.
Ikon shocks for your BMW! https://www.ikonshocksusa.com/
Old 03-19-2012, 08:09 PM
unsafe at any speed
wswartzwel's Avatar
Better show them how to unsnap the cover while your at it.
Bill Swartzwelder
Old 03-20-2012, 05:39 AM
RBMann's Avatar
Mine have always been zip tied so I learned how to pop the cover off while they are in place. I don't remember if the zip ties were OEM.
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S.
* 2000 S, color-Salmon 108K+ -sold
* '17 Africa Twin-totaled* '09 F650GS twin-sold
* '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ.
Old 03-20-2012, 09:41 AM
Misfit
Noblehops's Avatar
I should have mentioned - my left one was ziptied, but I couldn't see a good reason why, and thinking about the guys that were having trouble with this, and the potential to need to access it by the side of the road, I removed it. It did NOT look OEM, was kind-of askance.
N.
Old 03-20-2012, 10:50 AM
Corky's Avatar
Pretty easy to do once you've done it a few times.
It's all right in front of your eyes, it's just whether u can get your fingers in there without drawing blood. The fuse placement inside the fusebox is in the manual.
If U do it the hard way by taking the fairing off U learn quick. That is a pain in the hind end.
2010 Ducati Multisrada 1200 touring
2004 BMW R1100S
2004 KTM 450 EKC plated
2002 Honda XR650R-Baja winner
1998 Yamaha Warrior sport quad
Old 03-20-2012, 11:19 AM
