Need help
I installed the WIdeBand Power Commander and the bike starts. But, no throttle position showing on monitor and AF is anywhere from 11 to 13. Also the 02 does not light up but will blink (on return to idle) if I blip the throttle. I've tried the maps provided and a 0 map. I tried with the 9v and without.
I ordered the AF gauge and it should be here tomorrow.
Please help.
Philip
Old 04-18-2012, 12:49 PM
OK. I got the throttle position to show on the monitor. The AF showed the right ratio but when I turned the bike off and restarted it was back to the 11 to 13+ area again. The 02 light is blue.
The only manual I can find is the power commander but not the wide band. Is there a wide band manual available? If one of you have on can you send me the pdf?
Philip
Old 04-18-2012, 02:13 PM
I figured it out, without a manual. But I do need to find a manual.
Philip
Old 04-18-2012, 04:24 PM
