850dunstall's Avatar
replace o2 sensor
question, can the o2 sensor be removed without having to disconnect the header pipes? manual does not indicate process, it talks about whole exhaust system removal reinstall etc
my o2 sensor is behaving badly, disconnecting it brought back the smooth (i know it not that smooth, just don't let the bike know) running machine it used to be.
so i need to replace it, still have the full factory exhaust.
claus
IBA, 04r1100s, 11f800st, 74norton, 05f650gs
auf Adlers Fluegeln getragen...
Old 04-16-2012, 05:57 PM
Misfit
Noblehops's Avatar
Yeah, it simply unscrews from that bung. Follow it's wire, taking note of its routing, and unplug it, allowing you to unscrew the sensor without tangling the wire.
N.
Nils Menten - Tucson, Arizona, USA* 2001 R1100S "Light", gone but not forgotten. http://tinyurl.com/zv3tpc5
I Do Vapor Blasting! Visit restocycle.com for information.
Ikon shocks for your BMW! https://www.ikonshocksusa.com/
Old 04-16-2012, 08:33 PM
CoffeeGuy's Avatar
I removed my headers to approach the O2 sensor from the right side. Really wasn't a big deal as I was doing lots at the time. Not really certain I had to remove it, but made access to the sensor much easier.
Old 04-16-2012, 09:00 PM
Or jsut leave it unplugged. Cover the "bike side" of the plug very well so water can't get at it.
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 04-17-2012, 03:06 AM
goter done
well i did without pulling the exhaust or cat.
B I T C H to get in there,
with it hooked up and warmed up, got a nice idle, all the roughness is gone
yeehaa! time to ride
claus
Old 04-17-2012, 08:26 PM
Misfit
Noblehops's Avatar
I'm confused - did you remove this, or replace this?
N.
Old 04-18-2012, 05:36 AM
N.
replaced the o2 sensor with pulling the mufflers and cat
claus
Old 04-18-2012, 12:06 PM
