twin cam oil weight question
I have a question, my owners manual says the twin cam should use 10w40 or 10w50. I have allways used 20w50....any cam head guys use 20w50?
TIA, Lane
2005 Boxercup, 2013 R1200GS Rallye, 2011 Triumph 675 Daytona, Honda MB5, 2011 KTM300xc, 1975 Bultaco, 1992 Beta, 1972 Aermacchi |
Ride Free or Die
I split the difference at Wally World and got M1 15w50. Engine is still in one piece. Used it on oil/hex heads too. And my Harleys.
Well I do the same, but the book says diferent so just wonder others feel about it.
Ride Free or Die
I guess it would be a factor if I lived in a cold climate; but, that's not the case. I spend most of my time worring if the 50 weight is enough.
Do a google search for 'mobil 1 10w-40 15w-50 pds' . There's one product data sheet with both oils on the same page for comparison. Look at the high and lower temperature viscosities and you'll see that the low temp viscosity is quite a bit different while the high temp viscosity only has a few points difference. While I have my own take on this, opinions vary, especially here.
I've attached an analysis of un-used Mobil 1 15W-50 just for entertainment purposes.
tm (R12, R11, R1) + 00 then S, S, /7 |
Thanks TM. I just bought as 2013gs cam-head so I want to do the right thing and also cover my butt. The owners manual is more complex than it needs to be. I think 20-conventional oil will be fine for break in. I would probably worry more if they called for a 10w60 like in the M cars.
Lane
Uh....who me?
Lane I use 20w-50 full synth for everything. Makes it easier when you have multiple bikes and it hasn't been a problem.
Bob Hancock '20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss "There are times when good words are to be left unsaid out of esteem for silence." St. Benedict |
Ride Free or Die
The new question that pops into my head is, now that BMW is going water/air cooled and using a wet clutch, will the Wally World M1 auto synthetic oil be appropriate? This is a bit of thread drift; but, your question seems to have benn answered, Lane.
Talk Less, Say More
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
Did you buy a Harley?
Mobil 1 20w50 for the real "Twin Cam."
cRaIg CaRr 2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer. |
But, we have a good opportunity here. If you use the 20W, and we can get someone else with the same engine to use the 10W then change the oil at the same break-in interval, take samples and have both tested, we can have some top notch data to use later. Break in oil samples usually have higher levels of metals from the break in process. The difference will give us the whole story. Blackstone Labs- $25/sample.
tm (R12, R11, R1) + 00 then S, S, /7 Last edited by tm1100s; 04-09-2013 at 08:05 AM.. |
Ride Free or Die
Craig, no, I bought a GS that is a twin cam. It is basically like the HP2S engine but detuned and probably less exotic internals. I am going to us 10w40 as per the manual and at 6000 miles switch to the recommended 10w50 synthetic.
Thanks for the input guys, Lane
Talk Less, Say More
I think in 2013 the motivation for 10W is the fuel economy numbers.
Kent Christensen Albuquerque '12 R1200RT, '02 R1100S '01 Boxster |
Someone in here has worked for an oil company and was involved with this. Who was that? I'd like to get the inside information.
I went with 10w40 like the book calls for, and I talked with my parts and he said the that's what they use in the twin cam bikes. When I get to the 6k mark I will go to the spec. 10w50 syn. I am doing this more for CYA than anything else as I am sure 20w50 is fine.
Lane
I will say the the gas mileage is better than any bike I have ever owned. I am running fairly hard, brisk take offs and I am getting 48-49 mpg indicated by the computer. It will be interesting to see what I will get once engine break in is complete and riding conservative.
Ride Free or Die
Lane, as you know, gas mileage on these bikes is altitude dependent. The HP2 Sport came frome the factory with full syn oil in the crankcase. burnishing in the branes is probably more critical than anything you'll do with the engine. Have a nice day.
