-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   Stumped-troubleshooting issue (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/746001-stumped-troubleshooting-issue.html)
Phil Y 04-22-2013 03:17 PM
Replaced my right head (don't ask--whole 'nother thread!) and bike was running fine. Just about 600 miles and time to retorque the head but right cylinder all of a sudden, started running ratty (based on unscientific but discernible hand-above-header temp difference). Bike runs fairly between 2.5-4K but there is no power or acceleration. Won't idle below 2k. Oh, also replaced the fuel pump gasket to repair a leak. Checked to insure no lines were kinked. They weren't. Here's what I've done so far w/no success:
1. Change plugs
2. Swap stick coils side-to-side
3. Retorque head and adjust valves (they were a bit off but not much)
4. Swap injectors side-to-side
Since it's only on the right side, believe HES is ruled out. Looking for suggestions as to what to check/change. Bad main coil? Any suggestions will be greatly appreciated!
EZ-RIDER 04-22-2013 03:52 PM
Try looking at the Ignition sensor part # 12117673277
PFFOG 04-22-2013 04:08 PM
re-seat the throttle cable in the RH throttle body, my bet is you disturbed it when doing work.
Phil Y 04-22-2013 04:45 PM
@Richard--you're a genius! Cable housing had pulled out of the adjuster/stop. Reseated it and it purrs like a kitten!! THANK YOU!!
PFFOG 04-22-2013 05:08 PM
No genius, just a victim of the same error a few years back. Luckily I found it quick.
Glad I could help, after your recent trials and tribulations you needed a cheap quick fix.
Phil Y 04-22-2013 05:14 PM
Thanks again! Appreciate your sharing your lessons learned from hard knocks. I hope I'm good for a while! Ride safe! Do you really have nine bikes to choose from?!:eek:
X-Triple 04-25-2013 03:45 AM
Your are truly a Jedi Master. ;)
