Replace front Frame-neck
Hello,
Steering column snapped off from the neck, after a sliding fall on black ice. Could this bit get welded or, have it replaced? |
nope.
replace it.
'04 R1100s. I changed a couple o' things. |
Registered Agitator
What Brad says X 2
Expensive little piece..... |
Not when you consider a new one cost 830.00. tjs
Would a neck from a different model fit this, at all ? There are 1100R necks available on eBay, less dear to these.
Don't know the condition, but it's cheaper:
edit: Nevermind. Not all the photos were loading on my phone. This neck doesn't look so good.
2001 R1100S Last edited by TX_Biker_Scum; 11-29-2013 at 08:00 AM.. |
1. ask here (usually someone knows) 2. compare part numbers 3. sit 'em side by side. the one i see for sale is probably less than $200 with shipping and fondling. if it hasn't been tweaked, seems like it'd be worth the coinage. i don't think i'd ever be comfortable riding with a patched-up one.
The R1100S is unique and special...which means the upper frame piece is unique to this bike. Buy a used one on ebay and get your bike back together and on the road again.
Damn, I wish I could follow that advise.
Scott '98 R1100S - Triple Clamps, 10mm Shortened Telelever 2013 KTM 990 SMT, 2008 KTM 990 SDR |
Brent
if you get stuck for one I might have one with a broken fairing tab otherwise good
unsafe at any speed
Have you tried beemerboneyard.com ?
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
I see you
black ice? and you're ok? you're one lucky fella!
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Agree with flatbutt. Also how is the rest of the bike?
2005 Boxercup, 2013 R1200GS Rallye, 2011 Triumph 675 Daytona, Honda MB5, 2011 KTM300xc, 1975 Bultaco, 1992 Beta, 1972 Aermacchi |
I'm quite alright, just few bruises easy enough for the elastoplasts.
Oddly, it wasn't a particularly cold night. Apparently, there was a broken pipe or something causing a water stream to become the adversary. Worst bit was to get the bike back on from the lay. Riding shoes are utterly useless in such a situation. Far too slippery than I'd imagined. Well, off to get this fixed over the holidays. Thanks for asking though. |
beemerboneyard.com doesn't have 46512331387 on stock..on some list, at the moment.
Man it's flat out here!
It's been 7,166 miles since I hit the Deer that broke it off last year (Personally found out why Wisconsin ranks #7 for Deer Hits...), a trip to the Texas MotoGP is in there too. Glad I had it welded and saved my money.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD Last edited by R111S; 12-19-2013 at 04:30 AM.. |
Thread Tools | |
Rate This Thread | |
Tags |
front neck , steering column |
