-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   O2 Sensors (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/785649-o2-sensors.html)
kroberts 12-05-2013 04:54 PM
O2 Sensors
I used to mess around with E30 and E36 BMWs. Long ago the illuminati discovered that you could use the O2 sensor from a Ford straight 6 (IIRC) on the BMW engines. It was an easy way to save a hundred bucks or so. Any trick like that on my R11S?
TIA
JonyRR 12-05-2013 05:48 PM
if you don't care about soldering ends, a generic replacement form napa is like $46.00 if memory serves..
JonyRR 12-05-2013 05:50 PM
the generics went in my e34 530 3.0V8
kroberts 12-05-2013 06:15 PM
OK, I'll bite. I'm curious, tell me about your V8 powered E34.
Don Ro 12-05-2013 06:27 PM
Some have used the Bosch O2 Sensor (P/N: 13474) purchased at AutoZone in their R1100S.
Beemer Boneyard sells them, also.
JonyRR 12-05-2013 08:34 PM
Well, my 1994 530I is an E34.
It has a 3.0l dohc v8, I thought they were somewhat common.
I got a good'un, no nikasil issues, H&R lowering kit, bilsteins, 18" momos, earbleed stereo courtesy of daughter's hubby. Conforti chip, airbox mod, yadda-yadda. Fast enough to emulate the late FNF kid if you get it seriously wrong.
kroberts 12-06-2013 05:04 AM
I thought the 530's were all sixes and the 540's were the V8's?
"My bad" as they say. Thanks.
kroberts 12-11-2013 02:51 PM
Did some more searching and found this thread...
http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/212525-moybin-o2-sensor.html
RBMann 12-11-2013 08:43 PM
I used the Moybin sensor in my S and it is still working.
Chris Canning 12-12-2013 12:26 AM
If you buy a PC it comes with a replacement Bosch lamba sensor.
850dunstall 12-12-2013 05:35 AM
bosch 15109
the bosch 15109 has the correct connector on the end to fit the r1100s
Don Ro 12-13-2013 09:10 AM
"This does not fit your: 1999 BMW R1100S"
We're sorry.
We couldn't find any results for the 1999 BMW R1100S in this category.
› See all products that do fit the 1999 BMW R1100S.
Amazon.com: Bosch 15109 Oxygen Sensor, OE Type Fitment: Automotive
kroberts 12-13-2013 09:40 AM
I think the fact that this particular sensor fits the R1100s is just a coincidence. It uses a connector used by BMW on their cars.
R111S 12-19-2013 06:40 AM
Ditto!
850dunstall 12-19-2013 04:24 PM
We're sorry.
not to be a $h!t, but the amazon item is not showing the correct part #
you could go here
Bosch 15109 Oxygen Sensor | eBay
or here
EnDuraLast - BMW R & K Oxygen Sensor
my take on the various different part numbers has to do with the connectors and other stuff, the guts of the sensor for general use ( narrow band) i take to be the same,
so why not use one that matches the connect and approx length and save the hassle of trying to make the splice joint....
Don Ro 12-19-2013 04:32 PM
Agreed...why not? Good Point!
ckcarr 12-19-2013 06:23 PM
I used the RBMann sensor in my S and it still working.
RBMann 12-20-2013 08:30 AM
The joke is on me CK, I went back to stock. I thought I had a second one but can't find it. I picked up a used one off eBay for $25.
JonyRR 12-20-2013 11:53 AM
an 02 sensor is a 'wear item' much as an oil or air filter, just with a longer service life. I believe a standard intreval is 60K miles.
Sure, they go longer than that but part of a modern troubleshooting SOP should include a replacement decision.
my 530 car threw an '02 sensor' failure trouble code, I replaced both (factory stainless tube headers and dual exhausts) and that cured the issue I had..just my $.02
ckcarr 12-20-2013 08:43 PM
But you had a used one...
Anyway, now you have a skid plate too...
:D
