-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   Ohlins Install Problem (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/789070-ohlins-install-problem.html)
BrianG 12-27-2013 03:44 PM
The new rear Ohlins shock does not quite clear the lower edge of the upper shock mount casting. There is some contact with the upper Ohlins casting.
Is it normal to have to clearance the edge of the frame's casting to gain some space?
http://i82.photobucket.com/albums/j2...ps4fcaef3b.jpg
http://i82.photobucket.com/albums/j2...pse536d31d.jpg
Note
The top shock bolt is not fitting properly into its hole because of this interference.
http://i82.photobucket.com/albums/j2...ps28eb0884.jpg
brentw1 12-27-2013 05:11 PM
should clear with spare space, send it back
sgoodwin 12-27-2013 05:44 PM
What he said, I have no such problem with mine either. For what they charge you it should fit perfectly.
Mitch1100 12-27-2013 10:51 PM
My Wilbers
http://forums.pelicanparts.com/uploa...1388213407.jpg
VetteRacer 12-27-2013 11:21 PM
My ohlins is very close like OP pictures. If I have a few moments (and remember) in the morning I will take some pics of it.
Matt
brentw1 12-27-2013 11:27 PM
when I had mine rebuilt kyle said there were several major revisions to the r1100s rear
PFFOG 12-28-2013 04:21 AM
The one I had in the BCR was close too and showed signs of wearing after use. 10 minutes with a dremmel or file should fix it. On the bike side of course.
kroberts 12-28-2013 05:42 AM
After seeing those pix I went out and looked at mine. It's really close, probably just a few thousandths clearance, especially on the right side.
In fact it's so close that I'm going to take mine back off and add a few thousandths.
Chris Canning 12-28-2013 06:28 AM
Yup mine is the same,just it you'll have a slight wear mark but no big deal.
BrianG 12-28-2013 07:38 AM
Thanks guys!
Out comes the die grinder!
SmileWavy
BrianG 12-28-2013 01:47 PM
Some minor relieving of the frame's top shock mount casting on the lower and inside edge of the left ear, and a little more substantial work on the lower and outside egdes of the right side ear got me almost there.
It looks like extending the relief cut on the shock's reservoir neck might have been the answer, but I don't know where the channel is inside that casting, and an error there would be an expensive mistake, especially given the amount of metal taken off of that edge of the mount casting.
With the ears trimmed this much, the front of the shock's top casting was still just making contact at the center of the bottom of the frame casting. Just the lightest relieving of that spot with a Dremel sanding drum got me 0.050" clearance there when mounted and the swingarm at full extension.
The top mounting bolt is now a finger-fit into the hole with no contact of the shock to the upper mount casting.
Relieved Left Side
http://i82.photobucket.com/albums/j2...ps01e63fcd.jpg
Relieved Right Side
http://i82.photobucket.com/albums/j2...ps2c6a56f1.jpg
http://i82.photobucket.com/albums/j2...ps5183b6d5.jpg
brentw1 12-28-2013 03:08 PM
just saying I didn't have to grind anything
I will look at mine when I am at the shop next week
BrianG 12-28-2013 04:09 PM
Certainly, if the hole in the frame casting was set 1/8" down and 1/8" to the aft, none of this would have been necessary.
By the sounds of things from others, that variability seems to be within jig tolerances for this assembly. The OEM shock had plenty of clearance as it was.
bradzdotcom 12-28-2013 06:03 PM
given a couple more variables, like "flex" which we don't ever seem to talk about....
...looks like you're good to go, and even if it's on the edge, the only time it would clunk would be at full extension, which i believe is also AFTER the rear wheel has left the ground, which in turn could mean...
...if it does go full extension, the clunk might be classified as a "feature".
kind of like someone whacking a broomstick on the ceiling to quiet down the upstairs folks.
"bang-bang...what the hell is going on up there? knock it off!! take it down a notch!"
i've had dirt bikes that have done that to me...a nasty clunk in the rear at full extension when the rocker arm hit the frame.
it's made me pause and rethink my position (throttle position). most times i backed off.
most.
BrianG 12-28-2013 06:44 PM
most.
I wanted to have enough clearance to be able to try adding some length to the shock, since its length is adjustable.
brentw1 12-28-2013 06:52 PM
if you really have to do that with what ohlins is shipping now, I would return it and get the wilbers,
ted porter here in the us is a good supplier.
I know that ohlins has various top designs,
bradzdotcom 12-29-2013 06:30 AM
adding length to the shock isn't going to change the fixed point clearance between the shock and the frame.
eventually a few degrees of angle will come into play, but the junction of the shock and frame that you're dealing with doesn't have any idea how long the other end of the shock is.
Chris Canning 12-29-2013 07:12 AM
Exactly
BrianG 12-29-2013 08:58 AM
Actually, it does, and for exactly the reason you state. As the swing arm drops the lower attachment moves forward. Without the added clearance achieved by relieving the casting between the ears I could just barely force the lower mount bolt into place when the shock was at its shortest configuration, so there was already contact. I could not get the holes aligned enough to even get the bolt into place when the shock was lengthened that extra 10mm.
I realize that the arc of swing arm movement doesn't cause much forward movement of the lower shock mount, but it was that tight.
WandererR11S 12-29-2013 01:36 PM
All that money an you need to get a grinder out to make it fit...!!! Im thinking Ohlins need to Sort it... Mite be a good idea to send some photos off to ya Ohlins man, some feedback to the factory...
Jeremy.
BrianG 12-29-2013 02:38 PM
Jeremy.
Did that, too.
Chris Canning 12-29-2013 03:18 PM
Really does make you wonder how folks have been fitting the same old Ohlins to the same old 1100s all these years!!!:)
BrianG 12-29-2013 03:32 PM
Clearly, some people are happier than me to install parts with a hammer.:D
sgoodwin 12-29-2013 06:08 PM
They're former/present Harley owners most likely. :D
PFFOG 12-29-2013 06:53 PM
As someone stated, 1/8" further back or down and it does not hit. Mine didn't hit, until the upper bushing got some wear. and then just slightly.
My guess is the top casting is not exclusivly to the BMW shock, but used in a wide range of shock fitment,
