dismantle the handlebar
What's the best way to remove the handlebar from the front frame ? The only nut under the big BMW logo, neither tightens or loosens when a wrench is used.
Essentially, try to free the front frame of everything.
Old 12-27-2013, 06:03 PM
Registered Agitator
sgoodwin's Avatar
What bike? Handlebars are on the fork tubes not on any frame of 1100 & 1200s. Some pics would help explain what you're trying to do.
Old 12-27-2013, 06:17 PM
kpolito99's Avatar
If you are working on an R1200S you need to heat the nut to loosen the lock tight, insert an allen driver into the ball joint and then hold the large nut while turning the allen.
If you are working on a different machine things may be different.
You will have the rest of your life to remember. But what you have to remember depends on what you do today.
Current ride - 2007 BMW R1200S
Past bikes/sold - 1999 BMW R1100S/1994 Honda VFR 750/1989 Suzuki Katana 750/1982 Suzuki Katana GS1000SZ
Old 12-27-2013, 06:32 PM
It's a R1100s. Having to remove the front frame off of it, the nut is right underneath the BMW logo.
Old 12-27-2013, 06:57 PM
unsafe at any speed
wswartzwel's Avatar
Follow Kpolitos instructions. You heat the nut to +200 degrees… it has some wicked loctitie on it. then you put an allen wrench in the center of the bolt and simultaneously loosen the nut.
Some pictures in This Thread
Bill Swartzwelder
Old 12-27-2013, 07:54 PM
the procedure is quite similar to juggling while riding a unicycle, blindfolded in a skateboard park.
i watched motoyoyo scott do the removal process one time. made it look easy. then i saw jeff williams try it. same day, same tools, same driveway.
almost made him cry.
the good news is....you'll never get it off any other way than the system shown in the triple clamp thread linked above.
and you'll probably sacrifice at least one tool to the Installation Gods in the process.
yet you'll have a very special merit badge that few have earned.
bonus points if you casually mention removing it to the guys back in the bmw shop. if you time it right, they'll buy you something from the roach coach because they're so impressed.
"one of us....he's one of us" you'll hear them chant quietly.
'04 R1100s. I changed a couple o' things.
Old 12-28-2013, 06:52 AM
No try, do or not do
shreddr's Avatar
if you really want to remove the handlebar and not top clamp like everyone else has instructed you on how to do, all you need to do is loosen the top clamp pinch bolts (triple clamp and handlebar clamp), slide the fork tube down, remove the bolt holding the handlebar clamp to the triple clamp (underside of the triple clamp) and it comes right off. Many riders like to relocate the handlebar clamp to above the triple clamp for a more comfortable riding position.
2017 R1200GSW Rallye Shreddr Signature Model
Old 12-28-2013, 07:34 AM
unsafe at any speed
wswartzwel's Avatar
he has to remove the top clamp to replace the upper frame piece, which is in his other thread.
Bill Swartzwelder
Old 12-28-2013, 01:44 PM
shreddr's Avatar
I saw that after the fact. He should pull the subframe first then take the clamp off.
Old 12-28-2013, 03:20 PM
Gasteropod Rider
Meeni's Avatar
The re-torquing procedure is not obvious. Since it is a crucial safety piece, maybe you could use the help of a friend that knows, or a professional.
Clymer manual has a complete walk-through for all the steps involved in changing the front frame. I'd advise that you at least get a copy for yourself. For a big job like this the expense is quickly justified.
The upper fork brace is assembled with loctite 2701 (red), thighten to 130NM. It requires a special tool to at the same time tighten and keep the allen wrench in there. Cuting open a window into a 21mm (from memory, check) socket is the easier way to create that specialty tool.
Old 12-28-2013, 06:21 PM
Brent
yea I have torqued several of these with a normal socket and the pin part seems
to hold well enough to reach final torque specs without spinning.
of course you may have a different experience.
Old 12-28-2013, 06:42 PM
Brent
oh as a addendum I first tighten them to death with a box end holding the pin with
a allen, then final torque with a digital wrench and socket. you don't want to
distort the rubber boot on the top, also best done with the head straight forward for the
same reason.
Old 12-28-2013, 06:47 PM
Sorry, I haven't been clear. The idea is to replace/fix the frame. So, the top clamp has to be removed. This is the sole purpose of this exercise.
Sorry, I don't have a manual to look up. Perhaps, that's ought be the best course of action.
So, if I understand this correct : front wheel and forks have to be removed from the clamp; to release the frame ? Later, find tools to remove the clamp from the frame ?
Old 12-28-2013, 11:47 PM
This is the bottom view of the frame with the broken nib at the front. I was hoping, if this nut is removed, the frame would break away from the handlebars, clamp, cluster and such.
This shows the frame broken off the steering column. I really hope there is a way to keep the clamp and the forks unfettered.
Old 12-28-2013, 11:55 PM
shreddr's Avatar
Are you just replacing the frame element because the steering lock tab is broken off? Seems like a lot of work for an attribute that sees little real use other than pushing the bike around in the garage.
Old 12-29-2013, 07:02 AM
Registered Agitator
sgoodwin's Avatar
No s hit, I wouldn't even consider all that trouble for a steering lock, Just buy a disc lock or something similar (large pissed off dog maybe). Anyone wanting to steal your bike would snap that off in a heartbeat anyway.
Old 12-29-2013, 08:13 AM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
DISK LOCK?
No!!!
Classic mistake. The front fender is $600 if you were to replace new. Sure you can try and find a nice used one, but who knows the condition.
Do you know how many I've seen with damage from people forgetting the disk lock? Several.
BMW's are among the least stolen bikes out there. Just have comprehensive insurance...
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 12-29-2013, 08:29 AM
Registered Agitator
sgoodwin's Avatar
That's why you get one with the strap that goes up to the bars so you don't take off with it locked on. Personally I wouldn't use one either but it sure beats dismantling half your bike for a piece that is so easy to break, if you just gotta lock it somehow.
Old 12-29-2013, 08:42 AM
Brent
he has a broken fairing stay mount, which apparently is commonly broken in a spill.
I have one in the same state in my junk parts bin. his steering lock is on the top
of the casting and looks ok. but in general it is good to actually have the fairing attached
to the bike.
Old 12-29-2013, 08:49 AM
Brent
to answer the question, you shouldn't have to remove the forks or clamp
there should be enough space to slide it up. there are no springs in the upper
tubes and they will move freely if they are not damaged.
Old 12-29-2013, 08:52 AM
