Dark Side of the Force...
X-Triple's Avatar
Mounting GPS Options On R1200S
Hi All,
I would like to ask my peers on this board of trick ways to mount their GPS on their R1200S? I just picked up a Zumo 660 and looking for some great ideas.
Thanks,
-X
'04 R1100SA
'05 K1200S
'04 BCR
'07 K1200S
'07 R1200S
Old 05-15-2014, 06:48 PM
Enthusiast
sirius815's Avatar
I really liked the techmount. TECHMOUNT - Products
You'll need this too. http://www.techmounts.com/products/?page_function=detail&product_id=179
Old 05-15-2014, 10:27 PM
Droptarotter's Avatar
I drilled and tapped the inner end of my Heli bars, then installed a Ram ball mount. The GPS mount attaches to that with a short Ram arm.
Cheers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat
Old 05-16-2014, 05:02 AM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
I never found an easy way to do it on that bike.
Ztechnik mount.
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 05-16-2014, 05:16 AM
AZ-J's Avatar
Send a message via AIM to AZ-J
I love my Z-Technik Mount.
’68 R50/2(1968 was Dad's then mine to 1990) SOLD
’07 BMW F800S (3/2007-9/2008) LEMON'D
'07 BMW R1200S black CF/white tank panels (acquired 10/24/2008)
My bike here:
http://tiny.cc/MyBike
Old 05-16-2014, 08:13 AM
X-Triple's Avatar
Hi AZ,
This looks great. Could I get a side picture of the assembly you have chosen? Do you have a model number I can reference?
Thanks,
-X
'04 R1100SA
'05 K1200S
'04 BCR
'07 K1200S
'07 R1200S
Old 05-16-2014, 10:47 AM
LeftCoast Peter's Avatar
Although AZ-J's actual mount might be great I myself would extend the unit higher so that you can look at the GPS without your head being pointed right down.
Mine was the second picture down:
R1200S GPS mount
2008 HP2S Sport Touring
2009 525 Beta RR
North Vancouver
Old 05-16-2014, 01:47 PM
Uh....who me?
Bob Hancock's Avatar
The most elegant way is the BMW mount and cradle as shown in the referenced thread above. That's the way I had it. I had a Motorrad IV in it.
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 05-16-2014, 05:11 PM
AZ-J's Avatar
Originally Posted by X-Triple View Post
Hi AZ,
Thanks,
-X
You need this piece:
National Cycle: Products: My Order
And below it shows a mate-plates, you need to pick one for the Zumo. It is easy.
this piece: http://shop.nationalcycle.com/perl/cycle/Z6032?mv_session_id=T6CbByyL&search_model=all%2d003""
It screws on the clutch handlebar assembly, adjusts and tighten up.
My bike here:
Old 05-16-2014, 06:42 PM
Wrong. Not even close. Not even in the same Universe. Coping is flattery. This is true. When Droptarotter copies your idea its like Davinci tipping his hat.
2009 525 Beta RR
North Vancouver
Old 05-16-2014, 08:51 PM
HP2 GPS Mount
I don't know if the 1200S is the same under the Roundel, but here is the mount I made for my HP2 Sport. I will vote that it is elegant. I made a stepped disc that fit the dimensions of the triple clamp and it will be attached by some sort of epoxy. There is a threaded hole in the center and the disc can be removed by using a longer bolt and pushing it off the ball joint.
So the final design is very simple, will work with the Techmounts GPS mount, Go Pro camera mount and their radar detector mount, It will also work with a RAM ball for those who want to go that route. There is a rubber band visible, which is only temporary for the photo. I didn’t want to secure the disc yet until after I get it anodized to match the triple clamp. Next week after the test drive, I will have to see if an angle block is necessary to give the GPS screen more sun protection for visibility.
[img]
Old 05-16-2014, 09:12 PM
Originally Posted by LeftCoast Peter View Post
Wrong. Not even close. Not even in the same Universe. Copying is flattery. This is true. When Droptarotter copies your idea its like Davinci tipping his hat.
Word!
The nice thing about LCP's install is that when you remove the arm/unit, you barely notice the remaining ball.
Drill both bars for an 8mm bolt while you are at it and mount the radar detector on the other side.
Cheers
Old 05-17-2014, 05:17 AM
X-Triple's Avatar
this piece: National Cycle: Products: My Order"
Thanks so much AZ and all; great options and ideas. I think i will go the AZ route of copying.
'04 R1100SA
'05 K1200S
'04 BCR
'07 K1200S
'07 R1200S
Old 05-17-2014, 07:00 AM
AZ-J's Avatar
Peter, you are wrong. When you remove the Z-Technik mount, you trade two screws for the one the mount came with.
My bike here:
Old 05-17-2014, 10:13 AM
EZ-RIDER's Avatar
Not the best photo's but I mounted the GPS to the Tank-bag and electrified the bag and mounted the Radar detector inside the map pocket
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel
1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Old 05-17-2014, 01:00 PM
No try, do or not do
shreddr's Avatar
Originally Posted by szazbo View Post
[img]
Cool Szazbo! I do like the roundel though, did you ever think of attaching something to the fork cap? They are so low function that you could probably carve out the whole cap and design the mount straight in, rather than adapt. I did this with my R12S and I thought it was a good location.
Garmin Quest
For my HP2S I would rather have an iphone mount on the fork cap with a power source.. That would have a whole lot of function!
2017 R1200GSW Rallye Shreddr Signature Model
Old 05-18-2014, 03:59 AM
AZ-J's Avatar
But an iPhone is not waterproof. A little rain can ruin it.
My 660 is waterproof at least 6'. I know because it fell in my pool once. It still worked!
My bike here:
Old 05-18-2014, 11:41 AM
AZ-J's Avatar
Also shredder. You could have mounted using the Z-Technik mount on the two screws holding the clutch mount. That would require using the two longer screws that come with the mount, and saving the shorter screws to replace it.
My bike here:
Old 05-18-2014, 11:44 AM
It doesn't get much easier than this, and you can choose the left or right. Fairing clearance might be an issue though.
2000 Cagiva Gran Canyon
2007 BMW R1200S
Old 05-19-2014, 04:23 AM
Dont taunt happy fun ball
AndrewA's Avatar
Send a message via AIM to AndrewA
I've got a Ram Ball mount setup that screws into to the bar end:
It attaches to an arm like this:
You'd still need the Garmin specific mount for your Zummo. It may not be gay enough for you, but you are welcome to it.
Old 05-20-2014, 09:39 AM
