Hello brothers, just wanted to mention that I am going to try some new battery types in the bikes here. They are so light I can not believe it. What are the thoughts out there on these new powerful light weights??
For the R11S the Standard Recommendation is their LFX18L1-BS12 MSRP: $186.95 The LFX Standard recommendation is the best overall pick for most applications, and has been selected to give strong cranking performance and long life-span. This LFX battery is 8.30 Lbs. lighter than the lead-acid 51913. Specifications: Voltage (V):12 A/Hr PbEq:18 Cranking CCA (A):270 Weight (grams):960.00 Weight (lbs.):2.12 Max Charge (A):18 and for the HP2: For the HP2 the Standard Recommendation is their LFX14A1-BS12 MSRP: $153.95 This LFX battery is 7.33 Lbs. lighter than the lead-acid YTX14-BS. Quantity: Specifications: Voltage (V):12 A/Hr PbEq:14 Cranking CCA (A):210 Weight (grams):830.00 Weight (lbs.) 1.83 Max Charge (A):14 Seems like a good way to cut weight on a already light bike. A battery that weights under 2 pounds for a HP is "way ok" in my book. The battery maker is Shorai and the case is made of carbon fiber. Japanese. Last edited by Dr. Curve; 01-05-2011 at 02:39 PM.. |
Initials & assault rifle
Posting a link is always nice:
http://www.shoraipower.com/p-151-lfx14a1-bs12.aspx An asian lithium ion battery in the krautvagen? The horror..............the horror.........
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER 1982 CBX | OLD SCHOOL 1969 H1 | QUESTIONABLE SANITY |
Underwater basketweaver
Nice... I'll have to bookmark this for when my battery dies in 22 months.
'05 R12GS '08 HP2 Sport '16 GT4 |
No try, do or not do
8 pounds is a significant weight savings in a critical (high) location, i assume it needs a special charger? i just bought a new odyssey so it should be a few years before i jump at it.
2017 R1200GSW Rallye Shreddr Signature Model |
Shreddr; Which Odyssey did you get? Cheers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat |
Strangely I got a phone middle of last year about lithium batteries,being the great non believer said yea yea yea and took no notice,but having since made some inquires looks like their coming up on the out rails at a pace!!
Shorai Batteries - I-BMW.com For what it's worth,Odyssey don't make batteries for motorcycles,their made for other applications,it just so happens there are an odd few that fit bikes. |
Not only you get your BMW's cheaper,you can include batteries in that as well.
Lithium Racing Battery - RB120223 - FREE UK DELIVERY |
Congoman
signit98 said the following when I posted a topic about these batteries in December.
I love the idea, and will probably end up with one, eventually.
Saw two trackside failures in Li-whatever batts (not sure of exact brand/flavor) last year that put me off a bit. Literally meltdowns. No big deal on an old sv or gixxer, but can't picture in even my aging duc or S, much less a nice HP2 etc. It's not common, but enough that I'm not _yet_ interested. And though the weight is pretty high, it's otherwise well centered, so it's a good benefit, not a great one. For a racebike that only had room for a bike back in the tail, I'd probably do it now. When all is right, they're definitely awesome. Stupid-light. Note, the current is good, but the capacity mediocre, so, if you have a bike that's hard to start (takes several goes, or gets started in the cold and ran for very short trips) it's not ideal either. Still, they're cool. The first time you hold one, you really struggle to believe it could start your bike. If you're not too risk adverse, go for it. I think they fall into functional-bling (not visible, and not needed, but with some actual benefit and cool-factor) If we get a small e-start motard built this year, IT will have one for sure. Or maybe in our Moriwaki. Still planning. Have fun with them guys,and keep us informed.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
Registered Agitator
Check out this version of lithium ferrous batteries. The drag racers are starting to use these as they save so much weight. These batteries will fire up large displacement bikes without a problem. If used in the cold it must be turned on to heat up then will fire the bike. Haven't heard of any fires or explosions from them.
speed-cell |
If there is to be a powerful and easy battery
A123 Motorrad-Batterie 13,2V 6900mAh "V2" - www.modellbaufuchs.de Works really well |
I have not bought one yet, however, I did see them at the dealership. I was surprised at how light they were. They seemed like they were prop batteries, not real batteries. They were priced a bit less than the BMW battery and a bit more than the Odyessey. They seemed very trick. I'm not worried about weight on my bike, if I were, I'd just loose weight. But, I'll definitely give these a good look when I'm in the market for a new battery.
Late to the party here, but for those of us with Non-ABS '99s would the LFX14L1-BS12 be adequate rather than the LFX18L1-BS12?
best, Dave David Soine 99 R11S |
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci 2007 Ducati 999S Team USA , 2005 BMW BCR R1100S 2001 Boxster S w/tip |
Barback King
...don't know if anyone has mentioned this, but over at ADVrider this shop sells them withan ADV 5% discount and they seem to be less than anywhere else...
5% Coupon code for SHORAI batteries, Per popular request, we just EXTENDED the month of JAN 2011: ADVshorai Thread: ADVmachines-SHORAI Lithium batteries-ADVrider - ADVrider Shop: SHORAI Batteries
R11S CNC BARBACKS |
Barback King
This came up, but don't know anything about the store: Moto Mummy about $20 off retail and it says free shippping...
R11S CNC BARBACKS |
