MarkC's Avatar
Location: While a member here: Japan - Germany - USA - Curently: UK
Twin spark engine pics
Someone on the ADVrider forum posted several nice pics of the new twin spark engine.
http://www.advrider.com/forums/showthread.php?s=&threadid=10170
MarkC
Old 12-10-2002, 02:57 PM
tominator's Avatar
Send a message via AIM to tominator Send a message via Yahoo to tominator
Thanks for the post.
Seems even BMW realizes that since there is so much volume inside the combustion chamber. Adding an additional spark plug helps improve the ignition latency due to the large displacement of our R259's.
I know the dual plug conversions really helps the older air heads, and am not surprised to see BMW introduce this to their product line.
I have personally converted two r100's using the services of SJBMW and their ignition kit with awesome results.
Cheers
Tomas
If it has two fun bags I'm in!
2003 R1150RT, 2006 Cadillac CTS,2000 GMC Sonoma Slammed, 81 Harley Davidson Shovelhead Stroker, Supportive Wife,Jack Russel Terrier and a 18 year old who things he's 23.
Old 12-10-2002, 03:02 PM
flynbmw's Avatar
Excuse me for asking but where does the second plug end up in the combustion chamber? I guess off to one side of the valves, coming in from the bottom. I understand the advantage on a two valve motor (see this years two valve Ducati's) but wonder how much it will help on a four valve head. Four valve heads usually have a centrally located plug in the center of the four valves. Will it cure the low RPM "knock" that strikes my motor sometimes? OK you "rocket scientists" out there, explain further please. Thanks in advance.
Harold
Old 12-10-2002, 04:17 PM
MarkC's Avatar
flynbmw; Member Steve Br, posted some info about the new heads. You can read his post here:
Dual Plugging on New Oilheads?
MarkC
Old 12-11-2002, 09:52 AM
flynbmw's Avatar
Thanks Mark!!!
Old 12-11-2002, 01:14 PM
