-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   Replacing and re-programming ignition switch (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/916229-replacing-re-programming-ignition-switch.html)
tm1100s 06-01-2016 10:07 AM
Upper ball joint tools.
http://forums.pelicanparts.com/uploa...1464800774.jpg
victorlaszlo 06-01-2016 10:55 AM
Originally Posted by brentw1 (Post 9143140)
technically I think this is one of the nuts that is supposed to be replaced.
bmw has some micro capsule thread locking stuff on it.
but honestly I dont think anyone does, thread locker wont hurt anything when you put it back together.
the manual says
Fork bridge to front frame
(clean thread + Loctite 2701)...................... 130 Nm
they also say to heat to 120c to remove but I havent had to.
the parts are all steel there are several things that should be heated to take apart
but they are alloy.
120 is quite a lot but how do you do that considering you need to hold the nut with an Allen key?
victorlaszlo 06-01-2016 10:57 AM
Originally Posted by Chris Canning (Post 9143169)
Blimey your starting to confuse me!!
You need a 22mm socket with a hole in for the Allen key and I've only ever found you get that with a spark plug socket.
Re the toque without the Allen key in middle you could turn that nut forever it won't come off,just tighten it too taste,the only time I ever use a torque wrench on the 1100s is the back wheel.
Getting confused too; is the nut 14 or 22 mm? Which equals the inner diameter of the socket (not the outer) :)
victorlaszlo 06-01-2016 01:19 PM
How do you get the bmw roundel out without damaging it? Wanted to check if my sockets work before ordering new ones :)
Chris Canning 06-01-2016 01:36 PM
The nut is 22mm you'll work it out when looking for 22mm socket with a hole in it.
victorlaszlo 06-01-2016 02:04 PM
Thanks Chris. And the badge, how is that one removed? Have tried some prying, but it feels brittle and I'm afraid of snapping/cracking it. Does it snap in, screw in, is there a trick?
brentw1 06-01-2016 02:32 PM
you dont need to remove the badge
leave it alone, the ball joint is underneath it but you arent going to remove it from
the top clamp
brentw1 06-01-2016 02:34 PM
the final torque wont move the center pin
just be careful to calculate it if you use a crows foot
I just tighten it
victorlaszlo 06-01-2016 02:37 PM
I'm referring to the badge covering the nut where the socket goes in this screen shot :
http://uploads.tapatalk-cdn.com/2016...cf290b87ba.jpg
brentw1 06-01-2016 03:22 PM
that photo is not a 1100s
the nut is on the bottom under the front frame
the photo appears to be a r1100rs not the same mounting
look on ebay for samples of what you should have
victorlaszlo 06-01-2016 04:05 PM
That explains things - thought it was the same clamp LOL
Had a look at mine and I seem to have a 21mm nut, perhaps it's different on the earlier machines...
Regardless, it will be tight with space in there :O
