diz plaz is cwazy
Wet bottom plugs
I took this weekend to do some maintenance on my 1100. While checking valve clearance that we perfect I removed all four plugs. Main plugs were fine grayish brown completely dry. Bottom plugs how ever were brown on the main electrode but had some oil on the threads. Should I be concerned. Bike runs smooth as silk no problems?
Life rewards action, He who is not afraid is safe! A Zest for living requires a willingness to die! -------------------------------------------------------- BWM R1100S 2004 (fat girl) BMW S1000RR 2011(skinny BMW R1200S 2007 (stingger) Honda CX500TC 1982 (turbo) |
Okay
Everything is fine. The bottom plugs always run a little richer. Just ride and forget about it.
Brent
as long as they are both the same
diz plaz is cwazy
One was wetter than the other but top plugs are identical all dry.
Brent
you might have a weak coil run it wihout the tops and see if it runs correctly
check it at high rpms as well. |
Thread Tools | |
Rate This Thread | |
