Desmodic's Avatar
R1200s Ohlins ride height adjustment
The Ohlins rear shock on my 1200s has a ride height adjuster, but it is impossible to use with the shock in place, even after removing the rear wheel, as the mounting is recessed into the swingarm, which prevents access to the adjustment nuts. I guess I'll have to detach the shock from the swing arm to make adjustment. Does anyone know the tightening torque for the shock mountings?
If anyone has a better idea of how to approach this I'd be very grateful.
Old 04-05-2009, 03:48 AM
Now ride a R1200R
Kieran R1100S's Avatar
I did it and you have to take the shock out. Also you will note that the incruments of ajustment is at 6mm. I adjusted mine to 12mm and after putting it all back can not notice a difference. I also coupled it with a 190/55 profile tyre and still can't notice any difference in turn in. The bike stands pretty tall at the seat. I think you will get a better result from removing the steering damper. I think that is what's retarding it from quick steering! I can't remember the torque setting.
Old 04-05-2009, 12:56 PM
You don't have to remove the shock. Spray both the adjusting nuts with WD40, then use the 3/4 opening wrench that came with the tool kit. Firstly unlock the locking nut (you do need to hold the shock body initially as you loosen the bolts, but afterwards its easy) and then adjust the other nut. The 3/4 wrench allows you to lift the wrench off the shaft and then relocate it to turn the nut. Hope this helps
Old 04-05-2009, 02:43 PM
roger albert's Avatar
Agreed, no need to remove the shock if my memory from the last 12S setup I did serves.
Man, unless the steering damper is damaged, it shouldn't be able to block out a 12mm height's effect on handling. 12mm has a MASSIVE affect on turn-in/agility/stability that can't blocked by any properly functioning damper. Yes, a damper can dull/dampen it, but turn-in is, in all but the very hardest/emergency scenario, a slow speed, nil-damper effect situation. Tell your damper to stop the chicanery
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 04-05-2009, 05:17 PM
Trackday junkie
Joe the Viking's Avatar
I removed the wheel but not the shock when i did my R12S, it works just like Brian says. And i agree that 12mm should make a massive change, mine went from R1100S "point-and-shoot" slow to "flick-it-like-an-actual-spors-bike" quick.
I design, build and test electric race bikes for http://www.morrismotorcycles.com
I'm also a track riding coach.
Old 04-05-2009, 10:20 PM
Now ride a R1200R
I changed the torque arm on my R1100S to a GS arm which was smaller and notice a huge difference to the bike turning in. I removed the shock from my R1200S because I couldn't see how it could be adjusted on the bike. I adjusted the ride hight to 12mm and like I said before it hasn't made a noticeable difference to me. I even went with a higher profile tyre to see if that would help but still no noticeable difference to me. Now what should be and what is, is 2 different things.
Old 04-05-2009, 11:25 PM
Desmodic's Avatar
Thanks all, I'll try your various suggestions
Old 04-06-2009, 12:25 AM
Desmodic's Avatar
Now I feel really stupid. The spanner in the tool kit - see pic - slots around the shaft of the dampers strut and slides up around the adjustment nuts. Easy. I didn't have to remove the shock, simply put the bike on a paddock stand and removed the rear wheel and the plastic splash guard on the shock.
I guess the moral of this is RTFM!
Thanks again for your help.
Old 04-06-2009, 04:48 AM
Haven't seen that wrench in the kits.
Would be handy.
Anyone else?
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 04-06-2009, 09:29 AM
I got that one in my toolkit with the bike.
Edd Fair
Charleston, South Carolina USA
R1200S Color No. 3
Old 04-06-2009, 01:36 PM
Thanks for the info. I could use that trackside on certain Elkas and Öhlins.
Will have to see if BMW has them available as a separate item, or if I have to track down a different Heyco source.
Thanks again.
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 04-06-2009, 02:02 PM
Don't put a shorter torque arm on a R1200S. If you are looking for more nimble handling, call Chris at San Jose BMW and order the adjustable torque he developed for his R1200S & HP2 Sport race bikes. About 6mm of extra length gives my R1200S very light and neutral steering. Completely different machine now. Wow, is an understatement!
Kent
"If you can't take a joke, you shouldna signed up."
Old 04-06-2009, 07:29 PM
Of course not. Obviously a 12 needs a longer arm vs shorter for an 11, but I don't think anyone was advocating a shorter arm on a 12 (but if I'm wrong, then good catch, Kent - that would be a horrible move)
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 04-06-2009, 08:07 PM
Read Kieran's comment about putting a GS torque arm on his R1100S too quickly.
Kieran,
To me, it looks like the rear ride height is not really increasing when you change the shock's length. What you add in shock length is taken away from ride height by the stock torque arm. You have to increase the length of the torque arm. BTW, with the adjustable torque arm you do not need to change the shock length if you stay within the 5mm to 10mm increase range Chris H. gave me.
As for switching from 50 to 55 profile on your 190 rear, that would increase rear ride height by about 4 mm. That may not be enough to notice. [correction] Ride would have changed by about 9mm and that should have made a diff. You sir, have a mystery.
Kent
Old 04-07-2009, 09:32 AM
It almost has to be a perception issue. You just CAN'T add 4, much less 12 mm of rideheight, and not get an effect. The effect is there, being physics based, whether a given rider is attuned enough to feel it or not. 4mm is pretty easy to feel. 12 impossible to miss, or so I'd have thought previously. I've never changed a bike more than 10mm without the owner proclaiming some "night and day difference' or some such. Heck, 12mm is enough to move some bikes from pushing to wagging. It's a VERY big change.
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 04-07-2009, 12:34 PM
Now ride a R1200R
Didn't get that in my kit. If I had I wouldn't have removed the shock.
I reckon what kokook has mentioned is probably the problem, that the torque arm is inhibiting it, not allowing for much change. Roger is wright that 12mm should have made a big difference but it hasn't. Will look at the adjustable arm.
Old 04-08-2009, 02:15 AM
Trackday junkie
The action of the torque arm does slightly compensate for lengthening the shock but it still makes a BIG difference in ride height and handling. On my old R12S i went from easily getting both my feet solidly planted on the ground to just barely getting the toes of both feet down. BIG difference.
I'll be adjusting my shock length in the next few days so I can do some measurements on it to get the actual figures.
Old 04-08-2009, 02:45 AM
Trackday junkie
BTW: My -06 R12S came with the wrench, i think the later ones didn't. I looked up the partno on www.realoem.com for you: 71117699986
Old 04-08-2009, 02:52 AM
bugslayer's Avatar
That wrench (aka spanner), along with a couple other shock specific ones, were additions to the stock tool kit that came with the Ohlins upgrade with my bike.
Old 04-09-2009, 01:38 AM
IainG's Avatar
I increased the ride height on mine a couple of days ago, but had to remove the shock bolt so I could swing it out to gain access to the adjusters - no suitable tool in my '07 toolkit.
I stupidly didn't take any measurements, but wound it down a good bit and what a difference! It shakes its head a bit more on the power over bumps, but nothing to worry about, however it now steers much more like I wanted it to
Black 07 R1200S - Ohlins, Helibars, Corbin Seat, Remus System, Puig Screen, Ventura Luggage
09 Honda DN01
Old 04-09-2009, 03:47 AM
