Help clarifying caliper bolt torque values
I've found two different torque values for front & rear brake caliper mounting bolts (2004 BCR): 40 Nm (PDF service manual) and 30 Nm (bikes owner's manual). Any idea which is correct?
Front bolts are M8 and rear is M10. Thanks |
BMW Motorrad Repair and Service Data says: 21 NM for the front. 40 NM for the rear. 2cnts from tjs
Use 40 Nm and it will strip, it's just a matter of time...ask me how I know!
Just keep in mind you're threading a steel bolt into soft aluminum... I'd suggest helecoil all the caliper mounts just as a precaution. |
Update. Nitro is right. I looked in an old 04 Maintenance Instruction manual. It says 30 Nm for all 3 calipers. I remember using 22 ft lbs. which is close. Never had a problem using that figure. tjs
Thanks all - I'll go with 30 Nm
| All times are GMT -8. The time now is 09:43 PM. |
