Clutch Alignment, a few questions:
i'm going to be replacing my rear main seals this weekend, as well as my friction plate. What is the story behind aligning the clutch?? I would think the 5 bolts would do this automatically. I've never worked on this or any clutch before so i really have no idea what "alignment" really refers to, i'm assuming its something about matching the splines for the input shaft or balancing everything, but not sure. can someone give me a basic explanation of "clutch alignment" and also, what can i use to perform this alignment besides the bmw tool?? thanks!
99R1100SA 84R100 |
Living on borrowed time!
I'll take a stab at this for you. First, don't be offended as what I say shouldn't be taken personally. BUT.
If you have never done a clutch job on a single-plate dry automotive-type clutch, you are in for a steep learning curve. Although this or any other mechanical device is just a collection of parts, the R1100S is difficult for the simple fact the entire rear half of the scoot has to come apart to do this. many have shadetreed this by tilting up the subframe, etc, ad nasuem, but I recommend complete disassembly both so you have easy access and to inspect the other components. You will need a heat gun to kill the loctite on the paralever pivot bolts and I recommend an IR thermometer to know when theye're hot enough (appx 240 degrees F). driveshaft reassembly and phasing can be difficult. Use NEW pivot pins if there is ANY galling on the inner pin surface and plan on pivot bearings as they USUALLY are destroyed in the removal process.Once you get to the clutch, examine CLOSELY the surface of the flywheel; if you see any heat-discoloration patches, they can easily propagate into dangerous cracks; replace all the parts. I bought a clutch alignment tool but others have used broomsticks. use the xmission input shaft as a template. good luck as this is a major operation on any bmw oilhead. It gets simpler after you've done it once. air tools are nice, as is a lift. You will need to fab a cradle as the rear frame comes off and that contains the centerstand. If you'r used to a japanese motorcycle you'll feel like you are in the matrix as these beemer thingies are way different....
Better a has-been than a wanna-be 'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'. |
and as to the 'alignment' part, it's getting the clutch disc centered in the middle of the pressure plate so the xmission input shaft can slip into the center of the clutch disc with ease when the xmission is installed to the engine block. a little bit off here can cause lots of different problems. I'm anal, so I bought the BMW tool at $40.00USD, but others have used old input shafts, broomsticks diametered-down to fit, etc.
thanks jony,
i've got a pretty good idea of the dismantling process involved here, although i'm under the (mis)conception that i could remove the paralever and main frame as one unit to avoid the hastle of the pivot bolts. is this even possible??? i just wasn't sure about the process of aligning a clutch. from what i can gather, it's just inserting something like a dowel (metal or wooden) into the space where the input shaft goes when reassembling things??? do the plates have to be in any sort of relation to eachother? i'm assuming this will make more sense once i'm inside the machine.
99R1100SA 84R100 |
unsafe at any speed
Yes you can remove the swingarm assy still connected to the rear subframe. And reinstall... you will need a narrow prybar to re snap the front ujoint back on to the output shaft.I have pics somewhere... Not sure where though.
On the Clutch...As Jony says, you need to align the disk when you tighten the pressure blate bolts, otherwise the transmission input shaft will not slide into it when you are trying to reinstall the transmission. Also be careful when removing, and reinstalling the rear frame. It fits very close to fuel injection lines and if you get rough with it the injector fittings can be damaged.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 Last edited by wswartzwel; 06-20-2006 at 08:31 PM.. |
unsafe at any speed
Found some pics...
Here is mine... ![]() 2 weeks later... Here is Repoe3's Better image... and I cleaned my store room a little since I had company visiting ![]()
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
great, exactly what i was looking for, i saw repoe3's description of spline lube and figured that was the removal process i would go for
only trick will be dealing with the abs line, but i'll cross that hurdle when i come to it
99R1100SA 84R100 |
unsafe at any speed
Bill
How 'bout I just drop mine off at your place when my clutch goes out? I'll leave you a racier chain saw. Jim
down to jap bikes that run and a dead Norton |
unsafe at any speed
repoe3
I couldn't repair your brakes, so I made your horn louder. 2009 GSXR 750 2004 Tuono 2004 R1100SBX |
man, everytime i see pics from that procedure...oddly enough...i want to do it again. weird. i am sure with the miles i hope to put on the bike, there will be a couple opportunities in the future.
repoe3
unsafe at any speed
Your bike is very photogenic...
Re: Clutch Alignment, a few questions:
Bobby BMW Ducati & Husqvarna of Atlanta 06 HP2 SM, Akra Ti, RapidBike3, |
re chain saw, I have a nice German one taking up space. Mayhap Bill would get more use out of it than I do.
Jim
unsafe at any speed
What am I fixing to buy now??? Zundapp...
big blue tricycle stare down the darkness and watch it fade |
unsafe at any speed
My pond isn't big enough to dispose of any... um, well... lets just say you will have to behave...
Also the rear seals (2 of them) require a "Special Tool" to allow one to slide the seal over the angle cut. I made my own out of a Aerosol can lid. Rolling the seal back like a rubber is how you transfer the part onto this make shift transfer part. Also the first seal goes in All the way...measure the second before removing...if its too deep you will screw up the seal and it should last about 60 crank rotations before it chews up the seal because of the angle cut. (Part of the venting system)
Not a job for the faint at heart... As for the clutch...I use a bushing that fits in the spline then a punch similar in diameter so that i can "Center" the plate before torquing everything down.... Good Luck Tomas
If it has two fun bags I'm in! 2003 R1150RT, 2006 Cadillac CTS,2000 GMC Sonoma Slammed, 81 Harley Davidson Shovelhead Stroker, Supportive Wife,Jack Russel Terrier and a 18 year old who things he's 23. |
99R1100SA 84R100 |
