-   BMW Z3/Z4 Forum (http://forums.pelicanparts.com/bmw-z3-z4-forum/)
-   -   Xenon - not leveling? (http://forums.pelicanparts.com/bmw-z3-z4-forum/1009931-xenon-not-leveling.html)
Chris_Z4 10-09-2018 03:30 PM
Hi everyone SmileWavy, first post!
So my pride and joy has developed a little problem with it's headlight which has stopped self leveling (Z5 E85 '04 3.0i RHD), car has xenon's. One headlight does go through it's cycle and levels as required (passenger side) but the drivers side has stopped working and remains set at last position.
So far front load sensor has been replaced along with a completely new linkage, sensor may have been suspect but transpires it was good and now spare. Bumper has been off for a thorough inspection of the lights and took the liberty of swapping the stepper motors over so they are both good too (suspect motor worked on passenger side and good motor stopped working on drivers side).
Annoyingly it can spring to life for a couple of cycles after wiring everything back up (harness to headlight for the motor 6-pin) and the sensor plug but then it stops again (no motor) and can remain fully out or in on the motor winder and then needs manual adjustment again :mad:.
Updated my diags with ISTA-D and ran the full test on the car, then specifically the LSZ_2 light switch control unit which shows:
00001F LSZ2: Coils, stepping motors faulty
000021 LSZ2: Headl.v.a.cc, front load sensor, open circ.
Would the second fault cause the first, given I swapped the motors and both seem to work? If there's a short circuit, this would be the wiring from the sensor to the light switch, I need to run these tests?
https://www.pelicanparts.com/techarticles/BMW_Z4M/110-BODY-Xenon_Headlight_Height_Sensor_Replacement/110-BODY-Xenon_Headlight_Height_Sensor_Replacement.htm
Think there's a fair chance that the plug onto the load sensor might not be making the electrical contact as it's been off a few times and one of the plastic retainers has broken off (secured with the tie wrap), the voltage backprobe tests would indicate this?
Sorry to be lengthy and detailed, MOT is due on the car and I'm trying to avoid garage bills at the moment.
Thanks!
Chris.
