Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW Z3/Z4 Forum
Question Need taller gearing on 96 Z3
Hi guys, been reading alot about diff change many are swaping for shorter ratio.
I actualy need longer ratio...
car is 96 Z3 was 1.9L swaped for a 2.8L M52, then a C-1 Procharger was installed on pushing 8 PSI.
Now tires keeps on spinning on hard accelleration... !
Would anyone tried to swap ring and pinion from different diffs ?
I found a used 1997 328Is 2.93 rear diff, casing does not fit but does the ring and pinion could be exchage ??
Ben
Old 01-27-2004, 06:31 AM
Nobody have done some diff changes before ??
Please, give me some hints !
Ben
Old 01-29-2004, 03:49 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
An M52 with 8PSI? I think you'll find that your tires will spin with any diff ratio. Thats a pretty powerful combination in a lightweight car.
I think I remeber hearing somewhere that the Z3 used the rear end off the E30. If you are lookinf for tal gears, maybe the diff out of an 325e.
Old 01-29-2004, 08:42 AM
Thank you Jared !
I was thinking about swaping ring and pinion but... nobody seems to have done it before.
I'll see !
Ben
Old 01-29-2004, 08:50 AM
Probably because the diff itself is so easy to swap out. I dont think I would bother changing out the ring asnd pinion, but try to find an entire unit that will swap in.
Old 01-29-2004, 08:54 AM
Ok, so I checked my sources, the Z3 does in fact have the same rear end as the E30,l so what you will want to do is try to find a diff out of a 325e which has a ratio of 2.78
Check to see that the saes are the same, then swap out.
Old 01-29-2004, 08:59 AM
thanks !
Now I just need to find one.
Ben
Old 02-02-2004, 10:16 AM
Try eBay or depending where you are, local junkyards, I've found that www.recycler.com is always a good source for parts in the Los Angeles area..
Old 02-09-2004, 08:07 AM
thanks a lot Jared !
I am located in Montreal, Canada...
I'll try my local Junckyard
Thanks again for the great service
Ben
Old 02-09-2004, 09:07 AM
