Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW Z3/Z4 Forum
LinkBack Thread Tools Rating: Thread Rating: 1 votes, 2.00 average.
Z 3 1998 1.9 liter Damaged seat for water pump
Z3 1999 BMW 1.9 Liter 4 Cylinder
While removing broken tap from the bolt hole for the water pump, my dremel tool ground into the water pump seat (i.e. the engine block) leaving a 1/2 mm deep groove, 3 mm length, 2 mm wide next to the bolt hole (1 o'clock position) the groove is on the outside of the bolt hole (at the 2 o'clock position). The groove does not extend completely across the seat surface which is 10 mm in width.
Is there a gasket material that will stop future leaks or is a metal filler material recommended as the water pump does not have a gasket.
Old 11-27-2011, 12:06 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
A picture of the gouge would help here. I can't reccommend anything based on your description. I need to see it.
You may need to get creative with JB Weld.
Uh, the water pump does have a gasket. There's an O-ring that goes there.
Old 11-28-2011, 09:03 AM
yepp.. please upload a pic for better clarity.
Old 08-06-2012, 05:56 PM
