Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW Z3/Z4 Forum
randumbmw (guest)
Guest
Posts: n/a
I have a '94 325i and the heat works on 1, 3, and 4, but 2 just blows the same speed as 1. Do you think this is the blower resistor?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Blower Resistor Replacement
Old 05-14-2013, 04:56 AM
Nick at Pelican Parts's Avatar
It could be the resistor or the control. Best thing to do monitor the signal from the switch tot he resistor, when you switch speeds, voltage should change. If it does, replace the resistor.
- Nick
