Minimum rotor thickness for machining
Hi,
Just tested out my new quick jack (awesome) and I see it’s time to change the rear pads, did the fronts last year. Just wondering what the minimum thickness or the fronts and rear rotors are for machining? 06 Cayman S I need new tires so hoping not to have to change rotors as well as pads. Thanks in advance |
https://www.pelicanparts.com/techarticles/Boxster_Tech/55-BRAKES-Replacing_Brake_Discs/55-BRAKES-Replacing_Brake_Discs.htm
Front = 26.0 mm Rear = 22.0 mm |
Thanks Brian,
That’s minimum thickness, I am looking for min for machining |
It's been my experience that machining doesn't help with warp--they may not pulse for a while, but the pulse comes back pretty quick. |
| All times are GMT -8. The time now is 08:04 AM. |
