1998 Tiptronic auto transmission removal
Looking for a good you tube or other video on the removal of a tip gearbox.
There are differences to the manual gearbox.
Can someone share a link.
I have exhausted my search.
Old 03-19-2019, 08:15 PM
I haven't found a video, but removing the tip is pretty straightforward. The differences between the manual & the tip is that you need to unbolt the flexplate from the torque converter, get to it thru the hole where the starter sits. There's a plug down on the left side that you twist and pull, The linkage is on the left side near the rear of the trans. There are coolant hoses on the right side that need to be disconnected and a vacuum line that operated a vacuum switch on top of the trans. These are the differences. Otherwise it pulls out pretty much like the manual trans. On YouTube, Burner has a pretty good video.
I did mine when the engine & tip were out of the car, I think the hardest part is gonna be getting the 6 bolts out of the flexplate & torque converter.
Brian Lamberts
Tucson AZ
Old 03-21-2019, 04:48 PM
