Replacing front motor mount
Just finished replacing the front motor mount on my 1998 986 and thank you, thank you for your technical DIY page on how its done. The only problem I had was the difficulty in accomplishing it all on jack stands. Not all of my bones and joints move the way the needed so some inventiveness was required. THANKS GUYS
Administrator
Glad to hear that you found them useful. Let us know if you have any other questions.
All four corners need to be on jackstands, or else the car will try to fall off. And as you said, getting it high enough requires ingenuity. To R&R an engine requires that the rear of the car needs to be at least 30 inches off the ground. Air tools help alot, especially a good air impact. And specialized sockets. As I already own a decent compressor, loud! I also have had an HF air activated 12t bottle jack. And bought a nice new 2x10 or 12 board and cut it up into pads. A dozen or so pads are enough, 18 is even better. New lumber doesn't fall apart like older dried out stuff.
Brian Lamberts Tucson AZ Last edited by Brian in Tucson; 08-16-2019 at 12:51 PM.. |
