-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Things To Do While The Engine Is Out... (http://forums.pelicanparts.com/boxster-cayman-forum/1039208-things-do-while-engine-out.html)
Brian Minson 09-04-2019 05:32 PM
This weekend I will be starting the process of removing the engine from my Boxster, and once the replacement engine arrives I figured I would replace the following items:
- AOS
- RMS
- IMS
Depending on the condition of the clutch and etc, replace those as needed. Thus while I have the motor out, what other things should I do?
Thanks guys,
Brian
My Porsche Boxster YouTube Channel
CarGuyNeil 09-04-2019 07:01 PM
A new clutch should be a given. Why put a used one in when you already have it out?
husker boxster 09-05-2019 06:58 AM
Water pump
Brian in Tucson 09-05-2019 07:18 AM
Spark plugs, serpentine belt, any iffy hoses. I put a spin on oil filter adaptor, an underdrive crank pulley, flywheel bolts, water pump (oem). New front motor mount. New rear exhaust, headers* (not for auto. trans.) coolant, of course oem. New boots on the cv joints.
*headers may not be compatible with AZ smog testing.
Chi-Town 09-05-2019 08:07 AM
Spark plug tubes, vario-cam actuator gaskets
