-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Adding a Kill Switch (http://forums.pelicanparts.com/boxster-cayman-forum/1043819-adding-kill-switch.html)
Brian Minson 10-29-2019 09:27 AM
I wanted to ask if anyone has any suggestions on the best way to add a kill switch to a Boxster?
Brian :)
Brian in Tucson 10-30-2019 12:37 PM
Why isn't the ignition switch sufficient? Why do you feel you need a kill switch.
You probably could figure out some way to wire it into the fuse block, maybe the fuses for the injectors?
JFP in PA 10-30-2019 01:20 PM
While I believe it is totally unnecessary, if you put a switch on the crank position sensor, interrupting its signal will shut off the fuel and ignition systems.
t-tom 11-05-2019 03:33 PM
A PO wired a kill switch right at the battery on the 01 Boxster s I just bought. I'm assuming there is a parasitic draw some where in the electrical system. One of many fun things I get to fix.
