Brian Minson's Avatar
Adding a Kill Switch
I wanted to ask if anyone has any suggestions on the best way to add a kill switch to a Boxster?
Brian
Old 10-29-2019, 09:27 AM
Why isn't the ignition switch sufficient? Why do you feel you need a kill switch.
You probably could figure out some way to wire it into the fuse block, maybe the fuses for the injectors?
Brian Lamberts
Tucson AZ
Old 10-30-2019, 12:37 PM
JFP in PA's Avatar
While I believe it is totally unnecessary, if you put a switch on the crank position sensor, interrupting its signal will shut off the fuel and ignition systems.
Accrochez-vous bien de vos rêves..........."
Old 10-30-2019, 01:20 PM
t-tom's Avatar
A PO wired a kill switch right at the battery on the 01 Boxster s I just bought. I'm assuming there is a parasitic draw some where in the electrical system. One of many fun things I get to fix.
"Inside every old person is a young person saying WTF happened"
If guns cause crime, all mine are defective. Ted Nugent
1983 911 SC 1978 Land Cruiser FJ40 2001 Tundra
1971 Datsun Fairlady Z RHD (240z)
Old 11-05-2019, 03:33 PM
