Alternator problem
I have a 2004 Boxter S. A week ago the alternator light came on in the car. I checked the voltage at the battery while the car was running at it read 14.2. With the car stopped the battery read 12.5. Everything seemed to be working fine but I pulled the alternator and had it rebuilt. I reinstalled it today and the alternator light still comes on. I'm not sure where to look next and I haven't seen anyone else in the forums with a similar problem. Suggestions on what the problem could be?
Thanks, Dave |
Who rebuilt it and what did they replace? If they didn't replace the voltage regulator that would probably be your issue.
Available here on Pelican Part#000-043-206-37-OEM |
yes, they replaced the voltage regulator. I'm confident the alternator and voltage regulator is working properly.
I believe the blue wire attached to the alternator controls the dummy light. I assume if that is broken than I would the problem I'm describing. Can anyone confirm that? |
anyone?
The idiot light is powered and the voltage regulator provides the ground when the alternator is not working.
| All times are GMT -8. The time now is 04:46 AM. |
