Alternator problem
I have a 2004 Boxter S. A week ago the alternator light came on in the car. I checked the voltage at the battery while the car was running at it read 14.2. With the car stopped the battery read 12.5. Everything seemed to be working fine but I pulled the alternator and had it rebuilt. I reinstalled it today and the alternator light still comes on. I'm not sure where to look next and I haven't seen anyone else in the forums with a similar problem. Suggestions on what the problem could be?
Thanks,
Dave
'83 SC
'85 Carrera
Old 11-09-2019, 06:31 PM
Who rebuilt it and what did they replace? If they didn't replace the voltage regulator that would probably be your issue.
Available here on Pelican Part#000-043-206-37-OEM
Old 11-11-2019, 08:21 AM
yes, they replaced the voltage regulator. I'm confident the alternator and voltage regulator is working properly.
I believe the blue wire attached to the alternator controls the dummy light. I assume if that is broken than I would the problem I'm describing. Can anyone confirm that?
'83 SC
'85 Carrera
Old 11-11-2019, 08:32 AM
anyone?
'83 SC
'85 Carrera
Old 11-17-2019, 10:45 AM
The idiot light is powered and the voltage regulator provides the ground when the alternator is not working.
Old 11-19-2019, 09:19 AM
