High Mileage oil ?
Hi,
While I was pondering my use of Mobile 1 0w40 in my 125,000 mile 2002 Boxter S I stumbled across this:
https://mobiloil.com/en/motor-oils/mobil-1/mobil-1-high-mileage#10W-40#BVRRContainer
Then there is even a Super version:
https://mobiloil.com/en/motor-oils/mobil-super/mobil-super-high-mileage#10W-40
Anyone use it?
Cheers
Adrian
Old 11-29-2019, 05:19 AM
A high mileage oil may be OK, but you don't want to use either of the ones you've listed. The highest winter weight (the W figure) spec'd by Porsche is 5, not 10.
Regardless of what proper oil you use, lower miles between changes seems to influence engine health. It's est that 5-8K mi is the optimal interval between changes.
PCA National HPDE Instructor
2008 Boxster S Limited Edition #005
2008 Cayman S Sport - Signal Green
1989 928 S4 5spd
Old 11-29-2019, 05:44 AM
They do provide other grades 0w20, 5w20, 5w30, 10w30.
I'm signed up tothe 5K oil change interval but using Mobile 1 0w40 here in the UK.
I've a very slight weep in the RMS area and it was suggested my choice of oil was too light and that something thicker might work I was pondering 5w40.
I see in the Bentley manual it suggests for:
more than 50F/10C it has 10w40, 15w40 & 15W50
less than 50F/10C it has 10w40, 10w30 & 5W30
That made me go hunting for the owners manual - This might be from a 2006 (did it change?)
Old 11-29-2019, 06:42 AM
I cant see the difference between 5 and 10 weight being a motor breaker. Ive been using 10/40 HM for about 30k miles changing at 5k intervals. I just went to 5/30 for the winter a couple weeks ago because I plan on changing in the spring.
Old 11-29-2019, 05:42 PM
Now that we have that solved, what color windshield washer fluid do you use. I like the green stuff.
Brian Lamberts
Tucson AZ
Old 12-04-2019, 07:52 AM
Originally Posted by adrianw View Post
Hi,
Anyone use it?
Cheers
Adrian
Mobil 1 used to be the best until the U.S. E.P.A. got involved, you should do some research to see if your country has the good stuff.
Old 12-04-2019, 10:19 AM
Well, I once checked the specs for Mobil 1 ... 0W, 5W, and 10W all had the exact same cold pour point (-55F)
The only significance of the W number is related to how the oil flows at a cold start ... after that (after warmup), it's meaningless.
In addition, because this is full synthetic, there is no need for a lower number oil for winter, as a warmed up motor is a warmed up motor, regardless of ambient temperature. With full synthetics, the only real significance of 30, 40, or 50 is engine clearances and engine friction. For an old aircooled engine, built with looser tolerances, 50 is good, new water cooled motors are being built to tighter and tighter clearances these days, so much so that xW-20 or even XW-16 oils are specified. What ever is specified is good year around for full synthetics. If you're using Porsche A40-spec oil (as you should) it's full synthetic.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S
'01 Boxster
Old 12-10-2019, 10:29 AM
There are guys on forums that will argue all day that one has to run 0 -? weight oil. Anything else will kill your motor. It has to be true, they read it on the internet.
Old 12-10-2019, 11:14 AM
