-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Do I even need knock sensors? (http://forums.pelicanparts.com/boxster-cayman-forum/1046501-do-i-even-need-knock-sensors.html)
Formerly Steve Wilkinson 12-02-2019 08:14 AM
I'm about to have the starter replaced on my 2004 Boxster, and some people recommend having the knock sensors replaced at the same time, if you are accessing that top-of-engine area.
I religiously use nothing but Sunoco Tier One 93-octane fuel. Do I even need knock sensors?
JFP in PA 12-02-2019 09:42 AM
Yes.
colingreene 12-02-2019 09:45 AM
you could choose to not replace them however to run without them would result in a disaster
Jeff Alton 12-02-2019 10:17 PM
Yes you need them. No, they are not a common failure item....
Brian in Tucson 12-04-2019 07:46 AM
Yes. I think they tell the ECM about the octane of the gas you're using. ECMs don't like not knowing.
jluetjen 12-06-2019 04:19 AM
Not to mention, I suspect that the omission of the knock sensors will trigger an error code in the engine management system, and all that this entails.
