Do I even need knock sensors?
I'm about to have the starter replaced on my 2004 Boxster, and some people recommend having the knock sensors replaced at the same time, if you are accessing that top-of-engine area.
I religiously use nothing but Sunoco Tier One 93-octane fuel. Do I even need knock sensors?
Old 12-02-2019, 08:14 AM
JFP in PA's Avatar
Yes.
Accrochez-vous bien de vos rêves..........."
Old 12-02-2019, 09:42 AM
you could choose to not replace them however to run without them would result in a disaster
1976 914
1986 951
Old 12-02-2019, 09:45 AM
Jeff Alton's Avatar
Yes you need them. No, they are not a common failure item....
www.turn3autosport.com
Old 12-02-2019, 10:17 PM
Yes. I think they tell the ECM about the octane of the gas you're using. ECMs don't like not knowing.
Brian Lamberts
Tucson AZ
Old 12-04-2019, 07:46 AM
jluetjen's Avatar
Not to mention, I suspect that the omission of the knock sensors will trigger an error code in the engine management system, and all that this entails.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 12-06-2019, 04:19 AM
