-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Trans mounts not the same? (http://forums.pelicanparts.com/boxster-cayman-forum/1047503-trans-mounts-not-same.html)
turboflyer 12-14-2019 11:28 AM
So well into this project on the 01 Boxster S. According to the pn these are suppose to be correct. Anyone see the problem I see? That said I can offer that the torx nut is a 12x1.5mm. Same as a strut nut so I will be using those . Should make assemble and torquing must easier. Oh and warning not to turn that nut. As you can see it fits into a square mount. Obviously Porsche turned it.:)
http://forums.pelicanparts.com/uploa...1576351419.jpg
turboflyer 12-15-2019 05:20 PM
So has no one done this?
husker boxster 12-17-2019 05:47 AM
You might try 986forum.com. They are Boxster-centric there and have a ton of knowledge to share.
turboflyer 12-17-2019 07:13 AM
Will do. Thanks
turboflyer 01-03-2020 08:40 AM
Still waiting for the manufacturer to get back to me. They kindly reported that they use methods to ensure the item meets OEM standards. They were going to have their engineers check in to it. I won’t hold my breath and have already installed them.
Oh despite all the hype you do not have to remove the trans mounts to replace them. At least on an 01 986.
