turboflyer's Avatar
Trans mounts not the same?
So well into this project on the 01 Boxster S. According to the pn these are suppose to be correct. Anyone see the problem I see? That said I can offer that the torx nut is a 12x1.5mm. Same as a strut nut so I will be using those . Should make assemble and torquing must easier. Oh and warning not to turn that nut. As you can see it fits into a square mount. Obviously Porsche turned it.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci
2007 Ducati 999S Team USA , 2005 BMW BCR R1100S
2001 Boxster S w/tip
Old 12-14-2019, 11:28 AM
turboflyer's Avatar
So has no one done this?
Old 12-15-2019, 05:20 PM
You might try 986forum.com. They are Boxster-centric there and have a ton of knowledge to share.
PCA National HPDE Instructor
2008 Boxster S Limited Edition #005
2008 Cayman S Sport - Signal Green
1989 928 S4 5spd
Old 12-17-2019, 05:47 AM
turboflyer's Avatar
Will do. Thanks
Old 12-17-2019, 07:13 AM
turboflyer's Avatar
Still waiting for the manufacturer to get back to me. They kindly reported that they use methods to ensure the item meets OEM standards. They were going to have their engineers check in to it. I won’t hold my breath and have already installed them.
Oh despite all the hype you do not have to remove the trans mounts to replace them. At least on an 01 986.
Old 01-03-2020, 08:40 AM
