Thumbs up what did you do to yours today
97 boxster base , 260,000ks,. had a thought about electrical connections and dirt and corrosion. pulled, the negative batterey cable for saftey, and in turn pulled everey relay, and fuse one at a time. sprayed connecters and contacts with no spark cleaner. and worked each in and out several times. rebooted system cant hurt? next is a low temp thermostat, new coolant and water pump, and belt , courtesy pelican.
Old 04-10-2020, 09:10 AM
would like to add, tried to trade, this presentable everything works, have done brakes wheel bearings aos, new michelins etc. on an 07, in vancouver b.c. and was offered 1,800 canadian dollars on the trade. think i will keep loving it.
Old 04-10-2020, 09:17 AM
$1800 would hurt my feelings. No way Id let it go for that. Just have fun with it.
Old 04-16-2020, 09:19 PM
