DME question
Is there any difference between the dme for a manual vs one for a tiptronic? p/n are the same. Reason for asking is cause I need a new immobilizer and my car has symptoms of being bad per common issues listed by ecu doctors. Finding ecu, key & immobilizer all over for 2.7 manual cars but none for a tiptronic. Prices are cheaper then having mine repaired it looks like.
Imagine it's just programming differences between the base & S as well. If so I will just pull the trigger and have it towed to the shop for programming.
Old 08-31-2020, 05:15 PM
JFP in PA's Avatar
Yes. The DME for the Tip expects to see data from the Tip controller and will throw codes if it does not.
Accrochez-vous bien de vos rêves..........."
Old 09-01-2020, 06:57 AM
