Brake hard line part number needed, or source
I was installing stainless lines on my '06 Cayman S and at some point somebody cross threaded the fitting where the soft line ties into a hard line in the fender on the front left (driver side).
I want to replace this hard line but can't find it on the normal websites. It is a hard line that runs from the bulkhead fitting in the inner fender over to where the soft line ties in running to the caliper. I can take a pic if anybody needs clarification. I'm trying to find either a part number or a source for the line. Thanks, JD
'12 Cayman R 77 C3, 85 Carrera, 75 911S, 88 Carrera, 96 Carrera, '65 912, '06 Cayman S - Gone |
Because of the car's age, PCNA may no longer carry them, and aftermarket line companies like Inline Tube may not have them due to low demand. You may be forced to buy some tubing and fittings and bend one up yourself.
Accrochez-vous bien de vos rêves..........." |
The hard line was available, but I ended up having to call the dealership in order to find it.
For the record, I hope you post the part number when you get it and it fits the need.
Sure!
It is part# 997.355.175.11 This is the hard line that runs inside the driver side fender. One side is connected to a bulk head fitting behind the fender liner and the other side connects to the soft brake hose.
