starting problem
drove the car this morning, parked. Went out to put away, Neither key will start car. 2006 Boxster s, dash sees both keys but when turn switch no lights on dash and nothing happens
Non starter
I would think ignition switch. Best of luck.
Try replacing the battery in the key. Put the key in without turning it. The airbag light has to come on first and makes a click noise. Sometimes in my 06 Cayman, I have to take the key out, flip it over and try again. Not often but occasionally happens like that and it starts up.
Clutch sensor, push it in further or replace it. Sorry, didn’t read it all, if you put it to the first notch nothing happens?
The steering wheel has locked. Pull the steering wheel in the direction that has give, and hold it there. Turn the key toward the accessory position while keeping the steering wheel turned. If nothing happens, rock the steering wheel as you turn the key.
| All times are GMT -8. The time now is 11:50 PM. |
