starting problem
drove the car this morning, parked. Went out to put away, Neither key will start car. 2006 Boxster s, dash sees both keys but when turn switch no lights on dash and nothing happens
Old 07-26-2021, 11:46 AM
Ronpor
Non starter
I would think ignition switch. Best of luck.
Old 07-26-2021, 02:46 PM
Try replacing the battery in the key. Put the key in without turning it. The airbag light has to come on first and makes a click noise. Sometimes in my 06 Cayman, I have to take the key out, flip it over and try again. Not often but occasionally happens like that and it starts up.
Tony G
2000 Boxster S
Old 07-27-2021, 03:41 AM
It'll be legen-waitforit
stealthn's Avatar
Clutch sensor, push it in further or replace it. Sorry, didn’t read it all, if you put it to the first notch nothing happens?
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 08-04-2021, 05:32 PM
The steering wheel has locked. Pull the steering wheel in the direction that has give, and hold it there. Turn the key toward the accessory position while keeping the steering wheel turned. If nothing happens, rock the steering wheel as you turn the key.
Old 08-24-2021, 10:41 AM
