Looking for location of A/C Evaporator Housing Temp Switch
My 2008 Cayman S A/C compressor won't turn on, however, the 2 front fans turn on after 20 seconds and run continuously. My scanner indicates that the A/C evap sensor is reading -40 degrees. This reading prevents the A/C from turning on.
Part # is: 1H0-907-543-A. Diagrams show that it "should be" on the driver's side interior, above the floor vent! I have searched for the sensor location to no avail! Any idea where this sensor is hiding?? |
I also removed the battery and tray from the frunk hoping that it was on the other side of the firewall, again to no avail! |
Don't know what to tell you then, that is where that part number normally is located.
| All times are GMT -8. The time now is 03:21 AM. |
