Looking for location of A/C Evaporator Housing Temp Switch
My 2008 Cayman S A/C compressor won't turn on, however, the 2 front fans turn on after 20 seconds and run continuously. My scanner indicates that the A/C evap sensor is reading -40 degrees. This reading prevents the A/C from turning on.
Part # is: 1H0-907-543-A. Diagrams show that it "should be" on the driver's side interior, above the floor vent! I have searched for the sensor location to no avail!
Any idea where this sensor is hiding??
LouZ
'90 C2 TIP
'08 Cayman S
Old 03-23-2022, 09:52 AM
JFP in PA's Avatar
Accrochez-vous bien de vos rêves..........."
Old 03-23-2022, 10:33 AM
Originally Posted by JFP in PA View Post
That's exactly where it SHOULD be, unfortunately, it is not there. I actually removed the driver side duct to see if it was just hidden from view (and touch) and that area is a solid piece of plastic.
I also removed the battery and tray from the frunk hoping that it was on the other side of the firewall, again to no avail!
LouZ
'90 C2 TIP
'08 Cayman S
Old 03-23-2022, 11:26 AM
JFP in PA's Avatar
Don't know what to tell you then, that is where that part number normally is located.
Old 03-23-2022, 12:39 PM
